Where do you have your aftermarket amp located? (sedan)
Old Jun 18, 2006 | 08:40 PM
Dre's G's Avatar
I am currently shopping around for a 5 channel amp and have faced a dilemma. Most are huge, but the one I am interested in (Alpine MRV-F450) is not quite as big as the others. With this in mind, has anyone found a stealth location to store their amps besides taking out the spare tire? I was thinking of taking out the Bose amplifier under the rear deck and trying to fit it there...any opinions?
Dre'
Old Jun 18, 2006 | 09:42 PM
Godfather's Avatar
why not just mount to the rear seats? This way its not taking up any space and doesnt look bad....
Old Jun 18, 2006 | 09:49 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
If you have the premium with reclining rear seats.....
I have my Audison 5ch mounted behind the seat back; completely stealth.
Installed mesh at the top of the seat to let the heat rise.
Attached Thumbnails Where do you have your aftermarket amp located? (sedan)-amp.jpg   Where do you have your aftermarket amp located? (sedan)-amp005.jpg
Old Jun 18, 2006 | 11:47 PM
BigSash's Avatar
have you looked at the DLS RA50? it's relatively small for a 5 channel
Old Jun 19, 2006 | 03:08 PM
Gilley's Avatar
I mounted mine on the floor where it meets the back seat and built a protective shelf out of carpeted MDF to protect my 21 inch Xtant amp. I can throw anything in the trunk and not worry about damaging the amp. There is just a little step at the back og the seat on the floor.
I like the hidden Audison behind the seat back. That's a great idea.
Old Jun 19, 2006 | 04:24 PM
amthar's Avatar
FWIW, BigSash is correct with the exception of the Audison:
423.832825 in.^3 DLS Reference RA50
428.526684 in.^3 Alpine MRV-F450
430.051 in.^3 JL Audio 500/5
267.645259 in.^3 LPx600.5 Audison
The hit you take with the audison is obviously going to be output:
Audison:
60x4 180x1 @ 4
85x4 240x1 @ 2
DLS RA50:
70x4 265x1 @ 4
100x4 265x1 @ 2
note: both are probably underrated.
Old Jun 19, 2006 | 05:00 PM
BigSash's Avatar
yep DLS amps are highly under rated they seem to have a lot of head room
Old Jun 19, 2006 | 05:10 PM
sliderg35's Avatar
Does it interfere with the operation of the adjustable seat?
Old Jun 22, 2006 | 09:22 PM
InTgr8r's Avatar
Had to bend two rods on the back of the seat to clear the amp (see pic)
After that recliner works just fine.
Old Jun 22, 2006 | 09:50 PM
GeeMan's Avatar
Mine is on a little shelf in the trunk and interferes with nothing. It has a pretty small form factor though (DLS RA30). Pretty slick. You can't even see it looking from above. This photo is shooting from below.
Attached Thumbnails Where do you have your aftermarket amp located? (sedan)-dsc03302.jpg
Old Jun 23, 2006 | 01:50 PM
35bills's Avatar
GeeMan,
How is your amp handling heat buildup where its mounted? I'm concerned about heat dissipation for my application.
(I'm looking at different options as to areas for mounting an amp that is 23.25x7.5x2( Zapco)).
Trying for one amp but might have to consider going with two.
Thanks,
B.
Old Jun 23, 2006 | 05:21 PM
GeeMan's Avatar
So far no problems with heat. This is the first summer though as it was installed in Oct 05. We're due for a stretch of 90-100 weather here over the next week so it should be a good test. The installer didn't think it would be a problem. It may well be problematic with other amp designs. This particular amp is 15.15 x 9.65 x 2.33 and is a fanless design.
Old Jun 23, 2006 | 05:32 PM
anish3232's Avatar
Got a Amp Rack kind of thing built on the back of the seat.
Attached Thumbnails Where do you have your aftermarket amp located? (sedan)-100_0422-medium-.jpg
Old Jun 26, 2006 | 12:27 AM
bconrey's Avatar
Using the finish panel from the back of the seats as a template, I cut a board from mdf, carpeted it, and mounted it to the steel behind that finish panel. I went ahead and cut out the pass-thru hole so that functionality was not lost. I've got my NINe.4 on the right and room for another (future upgrade) on the left.
Brian
Old Jun 26, 2006 | 04:51 AM
G SEDAN's Avatar
Brian
sounds like a nice setup, any pix?
