Playstation Install Glove Box
Old Jun 26, 2006 | 11:57 AM
g35newbps2's Avatar
Hey can anyone tell me if they have installed a slim ps2 in their glove box? I hooked mine up but in reviewing the area where the wires run for the power cable and video it obviously doesn't sit flush so I can close the glove box. I was thinking about sawing out a hole in the back but when I feel how much space is between the glove box and a big piece of plastic is very small. Can anyone post up any pictures or tell me how you got yours to fit? Having to disconnect the cables is a pain in the a$$ and it looks ghetto.
Old Jun 26, 2006 | 12:24 PM
Otacon132's Avatar
it can be done - i cant beleive i dont have pics of mine - but yes, you need to open a hole in the back of the glove. And not only the glove, but also the whole entire glove box. It wont close right fi you dont open a complete clearance for the cables.
I cant take pics of the hole, but if you like ill take a pic of where the cables are coming in from and the PS2 later today.
Old Jun 26, 2006 | 01:27 PM
g35newbps2's Avatar
yeah man I would appreciate it. Do you see the hole where you cut out the glove box when you open it up? I take it you have to run the back of the cables parallel to the unit so it's not protruding out right?
Old Jun 26, 2006 | 01:58 PM
Otacon132's Avatar
you cant see the hole with the glove open when the PS2 is in - but since its always in you never see it. If you take out the PS2 you do see a big hole in the cornet though
Old Jun 26, 2006 | 02:29 PM
g35newbps2's Avatar
Ok sweet, more than likely the ps2 will not be going anywhere. If you can post up those pics tonight would be great. I want to do this asap, since right now I have the cables running on the top of the glove box to get it working and it looks quite ghetto.
Old Jun 26, 2006 | 02:31 PM
SFLG35's Avatar
FGC President
yeh you need a big hole
i made about a 2"x1" rectangle inorder to get the ps2 to close with the remotes still connected. you can not shut it with a memory card connected though. there is no way to go about cutting anything either to make it work, i have tried. the only thing that i can think of is to get a shorty memory card, but i cant seem to finda one that sells a shorter one then the standard sony memory cards.
if you do a search for my kenwood ddx 7015 install you can see the ps2 beginning hole i had to make it bigger to get it to shut though with the controllers still connected.
Old Jun 26, 2006 | 02:35 PM
Otacon132's Avatar
theres no way to get it to close with a memory card in - and to eliment wires just get some Logitech wireless remotes ~
Old Jun 26, 2006 | 02:38 PM
g35newbps2's Avatar
yeah I've got the wireless controllers already. I didn't want wires visible at all so I went and bought the wireless setup, but does yours close even with the controller receiver is connected after cutting out the back?
Old Jun 28, 2006 | 12:00 AM
g35newbps2's Avatar
hey ota any chance you got the pics up?
Old Jun 28, 2006 | 01:17 AM
k67p67's Avatar
I was able to cut 2 holes in the left rear corner of the upper glove compartment (one .5" round one for the power and a 1.5" x .5" rectangular one for the a/v plug). I can fully close the glove compartment with 2 controllers and memory card(s) plugged in. BTW, I found a DC power adapter for the PS2 so I didn't have to use a power invertor.
Attached Thumbnails Playstation Install Glove Box-dscf0829.jpg   Playstation Install Glove Box-dscf0831.jpg   Playstation Install Glove Box-dscf0832.jpg   Playstation Install Glove Box-dscf0835.jpg
Old Jun 28, 2006 | 01:32 AM
16psibrick's Avatar
sure why not
https://g35driver.com/forums/audio-video-electronics/94073-another-simple-g35-install-finished-pics.html
b
Old Jun 28, 2006 | 12:25 PM
g35newbps2's Avatar
sweet install guys! I'm hoping to achieve something similar in the lower glove box since my upper glove box houses my nav dvd-rom. I have to invest in a hack saw or something to do the cut out.
Old Jun 28, 2006 | 05:22 PM
Otacon132's Avatar
get a dremel
Old Jun 28, 2006 | 05:29 PM
SFLG35's Avatar
FGC President
you were able to do it cause you used the upper glove box, which is a very good idea. i however couldnt use that cause i have a 6 disc changer in there.
Old Jun 28, 2006 | 05:43 PM
SFLG35's Avatar
FGC President
here are soem pics of the hole i had to make
