Need help finding power wires for front component install
Old Jul 1, 2006 | 12:25 AM
ChuckP's Avatar
I am installing some CDT Cl-62 components up front, but i've run into a problem.
What wires do i tap to get power to my crossover? Do i use the stock woofer wires?
Thanks in advance.
Old Jul 1, 2006 | 01:09 AM
G35 Mass's Avatar
Uh, do you mean "audio signal" wire? or do you need +12vDC?
If you need + voltage, you're going to need to run lines into the door.
But I thought most crossovers are passive, therefore they dont require power to do the job. Just attach IN audio, and OUT to mid, and OUT to tweet
Old Jul 1, 2006 | 03:19 AM
ChuckP's Avatar
My question is: which wires do i use for the "IN audio"?
Without running new wires, using stock bose wires...am i making any sense?
Old Jul 1, 2006 | 12:08 PM
G35 Mass's Avatar
Yes, the wires attached to the blose speaker would hook in to the Audio In on the crossover...
Old Jul 1, 2006 | 05:30 PM
ChuckP's Avatar
Im assuming you are refering to the 6.5" woofer huh? Thanks for the help buddy.
Old Jul 4, 2006 | 02:59 PM
MiloX's Avatar
If you are looking for power wires for your passive crossover, I suggest you look for a shop for your install.
Old Jul 5, 2006 | 12:40 PM
badbread's Avatar
+1
hence the whole "passive crossover"
I'm installing my CL-61a's tonight and will take some pictures.
Old Jul 6, 2006 | 10:31 AM
badbread's Avatar
Hey dude,
Well I went to install my CL61's last night. I made the spacers, mounted the x-over, etc...
I cut the stock 6.5" plug going into the BLOSE speaker and used that to go to the "input" side of the crossover. I am not sure if that line is already x-over'd though. See my post below and I will get some pictures up tomorrow.
https://g35driver.com/forums/audio-video-electronics/106589-attn-those-who-using-stock-speaker-wire-w-aftermarket-amp.html
EnCr1pt3d
Jul 8, 2019 02:48 PM
newg37
Jul 26, 2015 09:32 AM
Thunderaan
Jul 22, 2015 07:40 PM
stay_tuned
Jul 21, 2015 07:09 PM
justgotg35
Jul 19, 2015 12:33 PM
