03-04 Double DIn Kit
Old Jul 11, 2006 | 07:25 PM
TBGee35's Avatar
Hey, I just ordered the Avic-Z1 for my 04 G35 Coupe (no factory nav) and was wondering if I needed to purchase the Double Din Finisher and the Bracket, or just the finisher, or what? Any help is appreciated, thanks!
Old Jul 11, 2006 | 11:01 PM
emtguy05's Avatar
im in the same boat as you, i know at grubbs there's 3 things to buy, the DD finisher, the DD bracket and the A/C controller...but do you really need all 3??
that comes out to $369. excluding tax & shippin.
Old Jul 11, 2006 | 11:11 PM
RedG's Avatar
<--12 More Years
Yes you would need all three of them to make it work, and if you have dual Climate control and want to keep it you have to solder the dual ac button from the old unit onto the new AC controller.
Old Jul 12, 2006 | 01:42 AM
HipHopPro's Avatar
"YOU DO NOT NEED THE BRACKET"
Old Jul 12, 2006 | 02:54 AM
RocketG35's Avatar
Why do I bother to DIY???
I also believe there are two brackets available - one for navi and one for non-navi equipped models. Make sure you get the right one.
Old Jul 12, 2006 | 10:10 AM
HipHopPro's Avatar
One more time: "YOU DO NOT NEED THE BRACKET"
Old Jul 12, 2006 | 10:33 AM
emtguy05's Avatar
I have the navigation and i want to keep the dual climate control...so all i need is the finisher and the A/C control...how come you dont need the bracket??
Old Jul 12, 2006 | 03:30 PM
Down_Shift's Avatar
My guess is you're using your original bracket with a bit of modifying depending on what unit you're trying to install... (might require cutting)..
You can order another bracket if you wish to return back to stock etc..
Old Jul 12, 2006 | 03:50 PM
badbread's Avatar
I installed a Z1 in my 04 coupe and didn't purchase the bracket and didn't need to cut anything.
Old Jul 12, 2006 | 04:11 PM
RedG's Avatar
<--12 More Years
You still need to solder the dual ac button.
Old Jul 25, 2006 | 10:16 AM
PimpinPearl's Avatar
is there a way to use the old a/c controller?
i think i read something awhile back where you could make sure it's on dual climate control before you unplug everything and then when you reinstall it just stays in dual mode....???
Old Jul 25, 2006 | 10:47 AM
emtguy05's Avatar
never heard of that
Old Jul 25, 2006 | 10:50 AM
conq's Avatar
I don't think you can use the old controller since it has the radio controls in it. If you're brave enough to hack off that part of the board , go for it.
Old Aug 4, 2006 | 08:58 PM
dj prophecy's Avatar
does any one know if the double din finisher at grubbs comes in the willow interior color so that it matches my interior?
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
mikemf8
Sep 3, 2015 08:01 PM
