AC Blowing Hot after DD/JDM Climate Control
Old Aug 9, 2006 | 01:51 PM
UrbanImport's Avatar
I did my DD/JDM Climate Control and converted it to dual. Now my AC blows hot. If I turn it all the way down to 60 it gets kinda cool but anywhere in the70s it is blowing out hot air. I thought I read something about this somewhere but i'm not seeing it.
Old Aug 9, 2006 | 02:18 PM
desidiva's Avatar
check the ribbon below where the stock bose HU would reside. I think if that becomes disconnected this problem can persist.
BTW my real screenname is Pdjafari but i've been BANNED!!
Old Aug 16, 2006 | 10:28 PM
RaFmAn123's Avatar
you forgot a plug
under drivers side dash there is a black tube and a little white plug that senses the temp in the car you forgot to plug it in. this should fix your problem
Old Aug 17, 2006 | 02:12 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
yup...that'll fix your problem. it is located underneath the driver side dash, on your far right hand side.
Old Aug 17, 2006 | 03:43 AM
nyckid's Avatar
hrmm, i don't ever remember touching or disconnecting anything like that when i did my DD install... hrmmm and my AC blows fine...
Old Aug 17, 2006 | 08:35 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
This is probably the most common problem after the DD install. There are 2 potential problems.
1. Most common.....you didn't completely or properly reconnect the AC adapter when you reconnected the HVAC unit. The AC plug is pretty picky on how it is connected. Disconnect the AC plug, taking careful account of the 2 little fragile retaining clips on the plug harness. Then, reconnect the 2 harnesses solidly and insert the 2 little retaining clips.
2. Less common....when you dropped (if you did) the panel under the steering wheel to get access to the driver side panel that borders the HVAC unit, you dislodged the in-cabin temp sensor. The temp sensor is that little vent grill that is near your right knee when you sit in the driver's seat. Check the white (or is it yellow?) harness behind the panel to see if that got loose somehow. When and if you dropped that panel, the wire harness there becomes very tight and could jar loose.
But, #1 is usually the problem.
Hope this helps. Many, many, many people have had this problem and I don't know why the AC plug harness is so sensitive...
doc
Old Aug 17, 2006 | 09:31 AM
Gilley's Avatar
You have to at least drop the panel under the steering wheel to gain access to the screws holding the radio panel in place.
NailBomb
Oct 28, 2015 07:53 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
AesonVirus
17 Inch
Sep 20, 2015 02:05 PM
