Homelink rolling codes?
Old Aug 18, 2006 | 11:33 PM
blacksheep1998's Avatar
I have an '06 premium, sport, aero. It has the homelink mirror.
Try as I may I cannot get the homelink to work my garage door. The manual says clear caodes for mirror, then press the button you want to program and the button on your current opener holding the current opener 2-3 inches from the mirror at the same time till the light blinks fast on the mirror.
Then it says hit the learn button on the garage door opener, then press the button 2-3 times on the mirror till it works.
I have tried clearing all the codes from my garage door opener, since i have programed so many cars to it over the years I figure maybe it could only hold like 6 devices. Still no luck, i can program my spare garage door opener to it no issue, so it is not a problem with the garage door opener. It is a Genie excellerator only about 3 years old. Never had a problem programming other homelink cars to it. Of course in the other cars all I had to do was hit learn in the garage hit the button in the car and was done. This one has to grab the freq from a working opener first for some reason.
Any one else have issues?
Thanks,
Pete
Old Aug 19, 2006 | 01:02 AM
LT1 SS's Avatar
when you push the learn button and go to push the button on the mirror hold the mirror button down instead of pushing it a few times. the lights on my opener flashes once they are linked.
Old Sep 30, 2006 | 11:13 AM
gnbtween's Avatar
Thanks,
Pete
I could not get mine to work with my old 350Z, but now I have it
working on my new G35.
My door opener is "rolling code" but old (1999)...so it takes two
people (or a rubber band) to get it programmed with HomeLink.
HomeLink programming w/older rolling code openers:
1. Have ladder ready (to reach door's "code" button)
2. Have second person in car
3. Park just outside garage, engine running
4. Close door w/remote
5. Clear HomeLink memory (see manual)
6. Program HomeLink w/remote (door will open)
7. Place ladder under door motor
8. Find door "code" button
9. Have second person press/hold Homelink button
10. At same time press/hold door "code" button til door's light blinks
11. Second person release HomeLink button
All Done.....Press/hold HomeLink button til door operates
If second person is not available, use rubber band w/ small wad of
masking tape to keep HomeLink button pressed in step "9"
We love our G!
Old Sep 30, 2006 | 11:44 AM
escobar929's Avatar
i never used another opener, i just did it thru the actual unit. took like 2 min to do it
Old May 8, 2007 | 11:53 PM
eriklevin's Avatar
Help... I am tired of walking in the house to open the garage door... We have an '07 G35S Sedan & an '02 Maxima SE... Two-car garage with a single (double) door and single opener... Is there any way to program each vehicle's HomeLink systems to control the same garage door? In the meantime, my fiancee gets dibs on the standard remote... Tired of the walk in the house to open the garage door. Help! Thanks.
Old May 9, 2007 | 12:04 AM
verbal assassin's Avatar
just read the direction. i did exactly what it said on the directions and it worked.
clear memory
press and hold both homelink button and ur garage door remote button.
wait for signal.
go to ur garage door opene, press the learn button.
go back to the homelink and press until gagage doors opens/shuts.
Old May 9, 2007 | 12:15 AM
nghiars's Avatar
yea.. follow the instructions above
Old May 9, 2007 | 01:13 AM
try programming ur cell phone to open the garage door. since ur wife has the dibs on the standard remote.
just program ur wife cell phone number. call her and tell her to open the damn garage.
Old May 9, 2007 | 08:45 AM
Gilley's Avatar
Both of my G's with Homeline are programmed to open the same garage door. I wish I could program them to open the gates at the front of my neighborhood.
Old May 18, 2007 | 11:36 PM
eriklevin's Avatar
Still problems programming...
Okay... My situation is still pretty much the same, but here are some more details:
Car 1: '07 G35s
Car 2: '02 Maxima SE
2-Car Garage - 1 Opener
As it is a newer opener, it seems I need to utilize the "learn" button on the main unit. Considering both vehicles have the HomeLink feature, can anyone walk me through the best approach (step-by-step) to programming both vehicles? Thanks.
Old Aug 2, 2009 | 10:34 PM
G35 Pilot's Avatar
Just in case anyone comes across the same problem I had. I've been screwing with the damm homelink for almost 3 hours today trying to get it to work. I have the intellicode Genie garage door opener with the rolling code, and I followed the instructions exactly but I could never get the homelink to blink rapidly when trying to do the initial program with the remote. Step 4 I think.
The problem was that if you a dual frequency remote, like some Genies have, it HAS to be set to 390mhz. After I flipped the switch, it worked like a charm.
I'm glad it works, I was so close to giving up and I read numerous posts on other forums, BMW, Lexus, with ppl having the same problem and not finding an answer.
http://www.genie-garage-door-openers...ictdcoding.htm
TO PROGRAM A HOMELINK DEVICE:
(This GDO is HomeLink compatible)
· Use a small flat screwdriver to switch the frequency selector to
· 390 MHz.
· Follow the HomeLink instructions in you cars owner’s manual.
· Reset the remote control frequency to 315 MHz for everyday use.
Cheers
Old May 4, 2011 | 10:25 PM
ineedone's Avatar
First goto your garage opener and clear all of the 'memorized' remotes.
Second re-program the hand held remotes.
Then follow these steps:
clear memory
wait for signal.
The reason you should clear the opener memory is most openers can only hold 5-7 remotes at one time. Worked for me perfectly on 3 remotes and 2 homelink transmitters today.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Detailed Image
Sep 28, 2015 07:04 AM
