Running a power cable?
Old Oct 19, 2003 | 11:23 AM
GforceI's Avatar
G SQUAD
Has any one run a power cable to the trunk yet? I need to get power in the trunk for an inverter and it looks like running a cable from the battery is the best way to go. I've ran power cables before but figured I'd see if anyone had any pointers for the coupe. Also any recomendation as to what kind of fuses/breakers I should put in?
Old Oct 19, 2003 | 11:34 AM
alwaysbetonblack's Avatar
Re: Running a power cable?
Behind the battery there is access to the interior of the car. You have to remove a piece of plastic that covers this area. Once you removie it you will see a rubber grommet with a cable running through it. You can feed in through here. I cut a little hole in the grommet and the taped it reall good. I used a 30 amp fuse for my audio amplifier. Depending on the current draw of whatever you are powering you may need to go higher. But i woundnt go below 30 amps.
2003.5 G35S, 6MT, BLACK ON BLACK
35% TINT
CLEAR CORNERS
EnCr1pt3d
Jul 8, 2019 02:48 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Thunderaan
Jul 22, 2015 07:40 PM
