How to Adjust Balance on JL 300/4 Amp ???
Old Sep 18, 2006 | 11:32 PM
qmaster8's Avatar
How do I adjust the balance on a JL Audio 300/4 amp? I know I am supposed to play with the input sensitivity but how do I know how much and which way to put it?
Also I get a bit of hissing at higher volumes. Should I increase the volume at the HU and lower the gain at the amp?
Thanks.
Jason
Old Oct 3, 2006 | 04:06 PM
steve465's Avatar
Use a voltmeter with the speakers disconnected. The User's Manual tells you exactly how to do it. Note... once you set the sensitivity at the proper voltage, do not increase it. It will only sound worse turning it up more and you will have defeated the purpose of setting at the proper voltage.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
