Help! JL 500/1 Amp is going loco
Old Oct 2, 2006 | 03:32 AM
spoiled808177's Avatar
My amp just turns on when it wants to...When the car starts up it takes the amp a while to turn on...i've notice that at low volumes the amp turns off but at higher volume it would turn on...The green light turns off and on when it wants to...I have it set up with the remote wire goes into my other amp and then goes out to the 500/1. What do I do?
Old Oct 2, 2006 | 03:58 AM
anDross's Avatar
check your amp fuse yo.. that could be it
anDross's Avatar
make sure that the fuse is fastened and all the grounds are as well
Old Oct 2, 2006 | 04:24 AM
where is the fuse located on the amp?? i dont see one
Old Oct 2, 2006 | 11:01 AM
mrdigital's Avatar
Not trying to insult your intelligence, but do you have signal sensing turned off or on?
Old Oct 2, 2006 | 12:28 PM
g35rcr's Avatar
there should be a fuse on the amp
Old Oct 2, 2006 | 05:09 PM
anDross's Avatar
well, try searching for the fuse under the hood.. near the battery terminal. then from there check the grounds.
Old Oct 2, 2006 | 07:15 PM
DaygoG35's Avatar
I have the same amp and their is no fuse on the amp. I say bring it back to your installer and have them determine if it is their wiring job. If the amp is the issue, get it serviced by JL. Hopefully you purchased it from an authorized JL retailer.
Old Oct 3, 2006 | 12:35 PM
gramdacious's Avatar
I think JL amps may have internal fuses. I have an e2150 and it says there is a 30amp fuse, however it isn't on the outside of the amp so I'm guessing it's inside. I know you can unscrew the sides, but that sounds kinda iffy.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
JustinMKN1
Sep 18, 2015 03:40 PM
