VSS wire Help
Old Oct 3, 2006 | 01:38 PM
nyclifeg's Avatar
VSS wire Help
I have a new 2006 6MT. I did a search for the last 4 days and still cant find anything. I know I read somewhere before that someone figured this out. I want to run a wire from the stock navi to the trunk release button in the glove box. I found the white and green wire in the 2x10 harness and cut the wire in half and ran it to the switch but the navi did not do anything. Has anyone tried this on an 06. I know that the white/green wire is the right one because I did an install on my girlfriends 05 g35 and everything worked out. Any help would be great thanks.
Old Oct 12, 2006 | 01:03 AM
billybrun's Avatar
Double check the wire you cut. The wire you're looking for is white with a green stripe. It's located on the longer plug out of the two that go to the navi unit (DVD-rom behind glove box).
Old Oct 12, 2006 | 06:45 AM
khsonic03's Avatar
This should be the same for your vehicle too. Bottom of the thread:
https://g35driver.com/forums/audio-video-electronics/120125-avic-z1-sedan-willow-color-match-pics.html
Old Oct 12, 2006 | 11:12 AM
nyclifeg's Avatar
Thanks for the info I will give it another try this weekend. I have taken the dash apart so many times it only takes about 20 min to take it apart and put it back together.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
