avic-z1 - new amp/speakers no more navi directions
Old Oct 3, 2006 | 07:52 PM
gqong's Avatar
I was wondering if anyone knows a possibility or if there is a dumb option to change the navigation voice and beeping noise when changing options to come on? I added a new amp and new front components the music sounds great but I no longer hear the beeping or the voice for the navigation. I searched and read through the instructions and I could not find an answer. Please let me know if there is a setting because I added a new amp and speakers which altered because I was on the factory amp/speakers and everything was working fine.
I am also aware of the volume settings i put them at max and still could not hear anything. so weird but the music is working perfect. i have the navi/beep set to L+R speakers but nothing. any help would be appreciated.
thanks
Old Oct 3, 2006 | 10:33 PM
NinivTA's Avatar
I know there's an option to change what will interrupt or sound when your music is playing including the phone or navi. I'm going out later tonight, so maybe I can be of more help when I'm actually in front of the unit.
Old Oct 3, 2006 | 10:51 PM
gqong's Avatar
yeah i set that to interrupt all :|
Old Oct 3, 2006 | 11:49 PM
gqong's Avatar
hmm someone on avic411.com said that it may be because I used the RCA outputs and if you use those supposedly you need the guide speaker. Anyone have a navi unit hooked to an amp and needed that speaker? Any input from anyone who has experienced the same please respond. thanks
Old Oct 4, 2006 | 12:22 AM
n2fooz's Avatar
You need to use the Nav Speaker wires and add a seperate speaker for it. They are Blue/White and White/ Black found in one of the plugs behind the radio. They aren't amplified so you may need to add a small amplified speaker.
Old Oct 4, 2006 | 10:28 AM
gqong's Avatar
Why would you need to do that, before I added the new stuff it was working fine and I did not need to tap into anohter harness to have those sounds. Just wondering the reasoning. Thanks
Old Oct 4, 2006 | 11:40 AM
gqong's Avatar
disreagard this message i figured it...im just dumb and swapped the wrong set of rca's i left the one connected to rear outputs. all is well now!
KruZZe
Feb 27, 2023 05:04 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Rose M
Oct 12, 2015 10:00 AM
