pioneer z1 bypass dvd?
Old Oct 8, 2006 | 09:23 PM
specialist's Avatar
i have a question to bypass the z1 pioneer do you need a module or can you just pulse the illuminate wire?
Old Oct 8, 2006 | 09:48 PM
redlude97's Avatar
depends on when it was built, from my understanding, if its built after June 06, then you are out of luck until someone finds a fix, the bypass doesn't work anymore.
Old Oct 8, 2006 | 10:27 PM
suprasam's Avatar
The is a new bypass module built by Ducatiboy in avic411.com. I have the old one and it does the job well, the new one for the z1 made after june 06 do the same.
Old Oct 10, 2006 | 01:30 PM
nchaurdia's Avatar
go to avic411.com for more info!
Old Oct 10, 2006 | 02:00 PM
gqong's Avatar
ducatiboy from avic411.com has a module to bypass z1's pre-july 06...after that you can do a similar bypass to the avicd1/d2 bypass. which is only swapping a wire and grounding.
Old Oct 10, 2006 | 03:09 PM
khsonic03's Avatar
^^^ +1. I have a unit built in July 06, and all I had to do was ground the ebrake, and swap a wire in the harness. SOOOOOOO EASY!!!
Old Oct 11, 2006 | 03:12 AM
drunkin master's Avatar
I am planning on getting either the z1 or n3. I have a 5AT. What do I need to do. Do I need to buy something else.
Hey khsonic03, can you be more specific on what you did.
Old Oct 11, 2006 | 07:08 AM
khsonic03's Avatar
http://www.sminntech.com/z1flash.html
Old Oct 11, 2006 | 12:49 PM
redlude97's Avatar
My bad about the false info, I hadn't checked the site for a while, and last time I checked there still wasn't a fix. Good to know that theres a way to bypass it now.
Old Oct 13, 2006 | 05:50 AM
spoiled808177's Avatar
i will confirm any z1 units built after Aug 06 does not need ducatiboys module...just ground the dam thing and change one of the wires =) enjoy!
Old Oct 15, 2006 | 09:57 AM
G35 Mass's Avatar
If anyone needs a module for a pre-july 06 z1, i purchased one, but have not bought a z1 and wont for a while as I'm back in school and spending all my "toy money" on the commute...... so I dont need it
PM me if you want to buy it
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
speedkills20
Oct 9, 2005 09:57 PM
Import-Tooner
Dec 19, 2004 11:11 PM
04g35cNJ
NorthEast
Jun 12, 2004 02:00 AM
