alternative to dynamat
Old Oct 20, 2006 | 11:09 AM
k67p67's Avatar
I didn't say the alternatives were the same as Dynamat. Dynamat is a great product no doubt but it is hideously expensive. A few of the alternatives like RAAMmat have evolved from asphalt-based to butyl-based products which are better. All the asphalt-based products would still do a better job than aluminum-covered bubble wrap. While adding mass is the goal, it isn't everything. Pliability, adhesion properties, and durability are key attributes to consider when choosing a deadener. Using a heat gun is a PITA. Deadeners that are too stiff to easily cover panel contours are also a PITA. I use and prefer RAAMmat combined with Ensolite closed cell foam. It's a much cheaper alternative than Dynamat.
Old Oct 20, 2006 | 11:43 AM
tkman00's Avatar
k67p67 - would you say the ensolite is worth it? i'm going to be ordering some raammat shortly for the doors.
Old Oct 20, 2006 | 12:07 PM
k67p67's Avatar
It depends on what your goals are for your deadening project. The Ensolite is more for sound absorption than for mass loading. It will muffle a vibration but not eliminate it. It is useful in doors and headliners for reducing road noise.
brianuc4
19
Apr 10, 2020 02:12 PM
Thebaws11
Nov 30, 2016 12:54 PM
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
