Need power connection
Old Nov 3, 2003 | 11:11 AM
SoCalTed's Avatar
Hey folks...
I am about to install some LED mood lights under the dash and in the door handles. I am using the Varad ILK103 (amber to match the console display) These LEDs have built-in resistors, so all I need is a switched 12v power supply.
So I was wondering if anyone had any ideas as to where to attach for power. preferrably I would only want the LEDs to turn on when the headlights are on, but I could live with them being on whenever the engine is on, since they have a 10K hour life.
Any suggestions?
Also, I have read somewhere that someone used Raybrig 29x8mm Festoon bulbs to replace the under-door lights. I am looking for amber festoon LEDs in amber if anyone has a source. Can we use 31x10mm? As that is all I can find. I cannot find any 29mm anywhere, other than those Raybrigs in hyper white.
Cheers, Ted
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click here for mods
Old Nov 3, 2003 | 11:34 AM
Meatshackle's Avatar
Deep Sea Moderator
Re: Need power connection
You can use either cigarette lighter. Then you have access on both sides and you only have to remove 3 or 4 screws.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, PS2, & TVs all up in the headrests.
Jax, FL
Old Nov 3, 2003 | 11:48 AM
SoCalTed's Avatar
Thanks Russ.... that's exactly what I am going to do... I am assuming that the power for the light around the bezel of the cig-lighter is controlled by the headlights, so that would make perfect sense!!
Now I just need to source some 29x8mm festoon LEDs, or find out if we can use 31x10mm LEDs. Anybody?
thanks again russ... -ted
Click here for mods
G35xdriver04
Nov 7, 2015 08:31 PM
Danielek
Oct 7, 2015 09:59 AM
JustinMKN1
Sep 18, 2015 03:40 PM
AT23
Sep 15, 2015 07:44 PM
