Replacement Subwoofer
Old Nov 7, 2003 | 09:46 PM
amg35's Avatar
Florida G35 Club
Re: Replacement Subwoofer
AngelC,
Correct type of sub, but 10" is too large for the factory location.
Take care,
amG35
2003 Silver Sedan
Old Nov 8, 2003 | 01:48 AM
AngelC's Avatar
Ah ok. Would replacing the stock Nd speaker actually make that much of a difference?
Old Nov 8, 2003 | 04:24 PM
amg35's Avatar
Florida G35 Club
Absolutely, if the free-air installation is executed properly.
Take care,
amG35
2003 Silver Sedan
Old Nov 9, 2003 | 08:21 AM
g35audioman's Avatar
kicker used to make a pair of 6x9 subs...try to see if you can find a shop that still sells them..i think the model number was F6x9C. Those would work great and they sound pretty good for 6x9 subs...
Old Nov 9, 2003 | 07:55 PM
AngelC's Avatar
Since I'm considering adding a 50x4 Amp along with replacing my other speakers, would I need an addition mono-amp to power the free air woofer? Or should I get an Amp with more channels? Any amp recommendations would also be great. Thanks for all the info.
Old Nov 9, 2003 | 09:06 PM
amg35's Avatar
Florida G35 Club
AngelC,
You can use the 4ch amp in 3ch mode with 2 channels in stereo for your mids and highs and the other 2 channels bridged to the subwoofer. You can buy a 5ch amp and have the ability to fade between your front and rear speakers. And as you have stated, you can buy a 2ch or mono amp to power the sub. Definitely power the sub in any configuration. Check out JL Audio's 500/5 amplifier.
Good luck,
amG35
2003 Silver Sedan
Old Nov 10, 2003 | 01:30 PM
RacerX's Avatar
I'm planning on two amps; a JL300/4 for the componenets and a JL 300/2 (bridged) for the sub. The main reason for my not using the 500/5 you mention is dimensions. It's too long to mount vertically on one side of the pass through (on the front trunk bulkhead). The 300/4 and 300/2 are shorter, and one will fit on each side of the pass through. As a skier, I want to keep my pass through. With a coupe, the 500/5 might fit in the stock amp location, but you'd better measure first; it's quite large.
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
Old Nov 10, 2003 | 06:43 PM
amg35's Avatar
Florida G35 Club
Consider the 250/1 instead of the 300/2 on bass. The 250/1 is a class D amplifier and you won't notice the difference between 250watts and 300watts. Physically the 250/1 is smaller and it incorporates an infrasonic filter which will limit over-excursion of the sub.
Take care,
amG35
2003 Silver Sedan
Old Nov 12, 2003 | 09:36 AM
RacerX's Avatar
<hr></blockquote>
Thanks, good sugestion, but I already have the 300/2. I do like the fact that it is the exact same dimensions as the 300/4, so it will be symetrical looking on the trunk bulkhead.
Old Nov 12, 2003 | 10:02 AM
AngelC's Avatar
I think I'm gonna jump on one of these..MTX Thunder 4405. What do you think amg35?
Old Nov 12, 2003 | 05:59 PM
amg35's Avatar
Florida G35 Club
AngelC,
My preference is for the JL amps. The MTX amplifier is considered a quality amp and would certainly be a great improvement over the factory amp. If you are getting a great deal, grab one.
Take care,
amG35
2003 Silver Sedan
Old Nov 15, 2003 | 07:10 AM
ydlee's Avatar
I am running the JL AUDIO E Series 6 channel amp to JL AUDIO 6.5 XR in the front and 5.25 XR Series to the rear. And the sub in the stock location with a 2003 model Kicker CompVR. Kicker CompVR handles more watts than the regular comp. I am running about 175 watts in 4 ohm with the gain on the amp to the max. However due to annoying rattle from third brake light I am dynamat Extreme the whole entire back dash from top and from under the trunk.
Old Nov 15, 2003 | 05:45 PM
steveniemi's Avatar
Here's my 12" IB JL
Old Nov 15, 2003 | 05:46 PM
steveniemi's Avatar
try again...
Old Nov 15, 2003 | 05:49 PM
  #30
steveniemi's Avatar
Go here
https://g35driver.com/forums/showfla...sed&sb=5&part=
