Replacement Subwoofer
Old Nov 4, 2003 | 11:54 AM
RacerX's Avatar
I am looking to replace my Bose subwoofer in my sedan. Can someone recommend a good alternative? I want to use the stock location, and I will be driving it with a JL Audio 300/2 amp (bridged).
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
Old Nov 5, 2003 | 06:55 AM
g35audioman's Avatar
Re: Replacement Subwoofer
check out jl audio subwoofers for that application. www.jlaudio.com.
Old Nov 5, 2003 | 09:25 AM
RacerX's Avatar
<hr></blockquote>
I've certainly heard that they are very good. Which model would be best assuming I want to mount in the stock location?
Old Nov 5, 2003 | 09:56 AM
amg35's Avatar
Florida G35 Club
Unfortunately, JL has discontinued their series of subs that would work in the factory location(infinite baffle). Try a local authorized JL dealer and ask for the IB series of subs, they may have a few remaining.
You can try another JL series, but you would have to build an enclosure into your rear deck. If you want to use the stock location and not build an enclosure, look for a sub that works in a free-air or infinite baffle arrangement.
Good luck,
amG35
2003 Silver Sedan
Old Nov 5, 2003 | 01:54 PM
RacerX's Avatar
What is the size of the stock sub? What model IB series should I look for?
Old Nov 5, 2003 | 10:17 PM
amg35's Avatar
Florida G35 Club
Look for 8IB-4. Hope you can find one.
Take care,
amG35
2003 Silver Sedan
Old Nov 6, 2003 | 07:31 AM
yea..good call...they are discontinued. Check ebay..they pop up there sometimes. If you think a 10 might fit, then check out the elemental designs E10o sub. It works great in IB. www.edesignaudio.com. I really like the way these subs perform. Very SQ oriented with great spl as well.
PS. I have a coupe so i dont have the sub in the rear..i have a pair of 6x9's so im not sure if a 10 fits back there...
Old Nov 6, 2003 | 09:58 AM
kG35's Avatar
I am actually looking into this as well. I don't have the Bose but still have the cutout in the back of my sedan. I found a kicker sub(comp c8) that can run free air. I don't know how good it is, however. I haven't been able to locate an 8IB4. There haven't been any on ebay recently.
Old Nov 6, 2003 | 12:10 PM
amg35's Avatar
Florida G35 Club
At one time, Kicker also made a free-air series of subs. I would check a local dealer and see if they are still available. The comp series was intended for sealed or bandpass enclosures. Regardless of the brand of sub you use in the factory location, ensure that you seal off the rear deck. Infinite baffle alignments mandate that the baffle be sealed, just like in a sealed enclosure.
Good luck,
amG35
2003 Silver Sedan
Old Nov 6, 2003 | 02:11 PM
kG35's Avatar
amg35,
Do you think maybe Crutchfield has the Kicker Comp C8 described incorrectly? In the link below it says that it is suitable for free air use.
http://www.crutchfield.com/S-sz8WIjM....asp?i=2063C84
Old Nov 6, 2003 | 02:19 PM
amg35's Avatar
Florida G35 Club
Crutchfield did describe the comp sub correctly, it can be used free-air. Its power handling will be decreased slightly, but it will work. Seal the rear deck.
Good luck,
amG35
2003 Silver Sedan
Old Nov 7, 2003 | 11:43 AM
AngelC's Avatar
How bout this one?
http://www.crutchfield.com/cgi-bin/S...SW254F&g=67600
Old Nov 7, 2003 | 01:58 PM
RacerX's Avatar
OK, the consensus seems to be a Free-Air sub is the ticket. Anyone know what is the biggest size that will fit without cutting???
Anyone do this mod yet???
Old Nov 7, 2003 | 05:12 PM
gticket's Avatar
Question... Can you just simply add an amp and sub to bose system. I was told you cant add to the bose system.
Old Nov 7, 2003 | 09:44 PM
amg35's Avatar
Florida G35 Club
8" Sub is the largest you can fit.
amG35
2003 Silver Sedan
