LED Mood lights installed
Old Nov 6, 2003 | 07:33 PM
SoCalTed's Avatar
thanks to everyone to gave me great suggestions over the last few weeks.
I finally got the LEDs installed as follows:
2 - driver footwells
2 - passenger footwells
1 - under passenger seat firing back
1 - under driver seat firing back
I used some 000 synthetic steel wool to scuff up the LEDs because the varads are focused almost to a pinpoint. Scuffing the tips (and a little on the sides) diffuses the light nicely.
I discovered that there was no power to the light around my driver side cigarette lighter!!! So I soldered wires directly into the power for the lighter. Ran those under the dash and connected into a 6-position barrier block.
then used barrier jumpers so that I have 3 hot and 3 ground positions.
I mounted the barrier under the dash to the right of the gas pedal (there's this chunk of plastic there that was perfect mounting place). If I need a quick bit of power, I can jack into this block now...
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click here for mods
Old Nov 8, 2003 | 10:53 PM
NYCGspot's Avatar
Re: LED Mood lights installed
sounds awesome...post pics when you get the time. Also, it'd make a great DIY job. I checked out your cardomain.com site...lol fai d la....go fasterrrrrr. ;]
Old Nov 9, 2003 | 04:46 PM
G35Lin's Avatar
Multi-Spoked Mod
ok ok. enough of the technical language! TALK ENGLISH TED! No understand. Show us some pics! Can u do this to my car if i like it?? Thanks!
Old Nov 10, 2003 | 10:04 PM
badboyg200's Avatar
ID LIKE TO SEE PICS OF IT TOO.. SO IF YOU CAN PLEASE POST REAL PICS OF IT INSTALLED.. THAT WOULD BE AWESOME.. THANKS
BaDbOy - "bLaCk BeAuTy"
http://www.cardomain.com/member_page...page_id=321439
Old Nov 11, 2003 | 03:15 AM
g35coupesoon's Avatar
pics bump
Old Nov 11, 2003 | 12:36 PM
SoCalTed's Avatar
OK - I am going to take some pixes today...but even in completed dark, with the low level on my Digi-cam I can't pick up the LEDs. I will take pixes of the install and enhance the "on" pixes.
G35Lin - ya, I can help you do this, now that I have figured out WTF to do. man was it a btch figuring it out! But the Varads made the job a lot easier once you figure out the power issue!
CLICK HERE FOR MODS - COMMENTS ALWAYS WELCOMED
Old Nov 11, 2003 | 01:17 PM
SoCalTed's Avatar
The PIX!! LED Mood lights
Here ya go:
Driver's Side
Passenger's side
Rear Driver Side
Rear Passenger
Both rears together
Power block - under dash driver side
Power running in console for under the seats
Under passenger seat
I still need to clean up the wiring, but I did this without removing my center console or any part of the dash. the only part that was "moved" to install this was to pop out the driver side cig lighter!
Cheers, ted
p.s. if you get a chance, register and vote for me over at Online Showoff THANKS!!
Old Nov 11, 2003 | 06:18 PM
Shader7's Avatar
Re: The PIX!! LED Mood lights
Are they wired to the headlight switch so they stay at night while driving, or just when you get in/out?
03.5 Coupe - Black/Willow, 6MT, Premium, Navi, Aero, Sat
Old Nov 11, 2003 | 07:04 PM
afr0puff's Avatar
Supa Dupa Moderator
<hr></blockquote> It seems like he went through the cigarette lighter ring, so yeah, they should only turn when the headlights on on. You don't need to worry about wiring into the headlight switch. They should also work with the dimmer switch... that's how I did mine.
http://www.anythingbox.net
Old Nov 11, 2003 | 07:16 PM
G35Lin's Avatar
Multi-Spoked Mod
:P Mine looks betta!
Hehehe. I have the neosn and they are brighter! But tahts it!
Old Nov 11, 2003 | 10:22 PM
fafafriendly's Avatar
Yo G35Lin, if yours is better...SHOW US SOME PICS!
Old Nov 11, 2003 | 11:23 PM
SoCalTed's Avatar
went thru the back of the cig lighter, not the "lighted bezel"
LEDs are on when the engine/ACC is on, not just when headlights are on. With 100,000 hour life span, no biggie:
G35Lin - -- bllllhhhh!!!!
[img]/w3timages/icons/smile.gif[/img]-Ted
Click here for MODS
Old Nov 12, 2003 | 01:26 PM
G35Lin's Avatar
Multi-Spoked Mod
This should suffice for now: http://www.onlineshowoff.com/index.a...ame=v35skyline
Will post more pics when i get home!
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
attarday
Jul 15, 2015 04:03 PM
