gauge power wire
gauge power wire
Any trouble running the 4 gauge power wire?
It isnt to fat? Meaning all your trim pieces sit in place properly, not being held up/out of place due to the wire?
If it is an issue, for 250-600 watts would 8 gauge be ok?
4 awg is fine to run. I was always advised that you shouldn't exceed 500watts on 8awg. JL recommends minimum of 8awg for their 500/1 and 300/4 if they are wired seperately. If they're on the same power wire with a dist block you need 4awg.
Danielek
May 1, 2022 01:28 PM
