DVD player and back up camara installed, need help.
Old Jan 8, 2007 | 07:42 PM
.:Brown Man:. J's Avatar
Originally Posted by tvandnav2go
Hi Brown Man
Hope all is well. If you don't ground the green and white wire you will not get video. You also must supply 12V and ground to the unit.
Thanks Dominic www.TVandNav2Go.com
hello dominic,
yes i've tried that also, and still no video or navigation displayed?
could connectors be bad?
i've tried grounding the blue/white and green/white still no display?
but for the black cable to power up the unit i connected to the lighter one for red and the other for black
Old Jan 9, 2007 | 04:39 PM
tvandnav2go's Avatar
Hi
If you feel the unit is defective send it back and I will give you a new one no problem.
Originally Posted by .:Brown Man:. J
hello dominic,
Old Jan 18, 2007 | 06:17 PM
Hi
very fast shipped back, very satisfied with the customer service, thanks dominic i'll will try and have the unit installed this weekend, will let you know how it goes,
Old Jan 19, 2007 | 07:35 PM
Cool
Hi Brown Man
Hope all is well.
Thanks Please let me know how you make out.
Old Jan 20, 2007 | 09:59 AM
TIRE_SMOKE96's Avatar
So, how did it turn out?
Old Jan 21, 2007 | 09:34 PM
urban's Avatar
If your asking me then I have checked it out and it looks like a defective box as if I remove the DVD RCA plug and put the back up camara plug it works which tells me that they are both hooked up correctly but only one output is working correctly. All I need now is to find time to get the guy back and uninstall the unit and send it to Dominic....that is tough with my work schedule right now.
Old Jan 22, 2007 | 06:59 PM
Hi Brown Man
Hope all is well.
lol things are well, as of now my dvd player works, and my audio input works, only the unit doesn't work, for some reason my navi and the dvd doesn't display at all, i've grounded the green/white, the black wire grounded, plug the connectors in, from stock connector, to tvandnav2go connector, to the back of the lcd screen display, powered up the unit (red light is on), plug the dvd video in to the unit video 1, rca ouput to the back of the lcd screen, i have the plug and play option, plug the battery back into the car and turned the car on, the screen is blank, flip the switch and still blank? but i didn't ground the wire to rgb pin 4, just grounded to chassy, and under the steering to? by any chance can you send me the diagram of which pin is which?
i know the unit is good, but could it be the connectors, might have a criss-cross in the wires? or no connection between the pins? cuz i did receive the same connectors back only the unit was different (new), oh yea dominic i sent you an email about sending me the instruction, i'mma have another installer do this for me see if they can make it work
Old Jan 22, 2007 | 07:12 PM
Hi Brown Man
Hope all is well. Please call Kim in the morning and I will have her send you a new cable. Maybe its the cable and not the unit. I sent you a new unit, but the same cable. 718-763-7367
Old Jan 22, 2007 | 07:14 PM
Hi urban
Whenever you get a chance send it back and I will exchange it no problem.
Old Jan 22, 2007 | 08:25 PM
Hi Brown Man
thanx dominic, i will call kim in the morning
Old Jan 22, 2007 | 08:47 PM
urban's Avatar
Hi urban
Thanks Dominic, your the best.
Old Jan 26, 2007 | 07:36 PM
Hi Brown Man
hi dominic,
hope everything is good, i just installed the unit this morning, it was actually the old cable that had the problem, with the new cable you sent me, the unit now works like a charm, picture is very clear and works great, i appreciate the customer service and for your help, you will hear from more customers soon, few of my other buddies planning to get it for their cars now too, acura rdx?, mercedes ml?, acura TL?, theres 2 more we'll keep in touch with you to see whats the status later on
but for now mine works great, take care. A++++++
JImmy
Old Jan 26, 2007 | 11:48 PM
alright you guys here are couple pix from my installation
looks great, quality is good enough for me, for a stock unit.
Attached Thumbnails DVD player and back up camara installed, need help.-img_0935.jpg   DVD player and back up camara installed, need help.-img_0936.jpg
Old Jan 26, 2007 | 11:50 PM
for some reason the resolution doesn't look as great as it looked in reality,
when your really watching in the car, looks 2 times better than that
i tink when i attached it to forum, must've automatically resized it
Old Jan 27, 2007 | 12:29 AM
  #30
heres the one at night pix
Attached Thumbnails DVD player and back up camara installed, need help.-img_0942.jpg   DVD player and back up camara installed, need help.-img_0939.jpg   DVD player and back up camara installed, need help.-img_0940.jpg   DVD player and back up camara installed, need help.-img_0941.jpg
