two 10" subs ran off a single 500/1 amp
Old Dec 4, 2006 | 07:38 AM
Obsidian G35's Avatar
Anyone running 2 JL 10W6V2's off of a single JL 500/1 amp? or a simular 2 sub system off a single 500watt amp? If so how does it sound? I know the amp will run both W6's, but I'm wondering how much louder it is than a single sub..
I guess my question is what hits harder..one sub getting 500watts or two subs getting 250watts each?
Old Dec 4, 2006 | 10:24 AM
BocaCoupe's Avatar
G's Up, Ho's Down
Its better to drive the speakers properly then underpower them. If you are dead set on running two subs, I would recommend 2 - 10w3v3 instead of the 2 - 10w6v2. They would sound great.
Old Dec 4, 2006 | 10:49 AM
seddon's Avatar
The JL500/1 will under power 2 W6's. With that amp I would run 1 W6 or if you want 2 then get a stronger amp.
Old Dec 4, 2006 | 11:16 AM
erdog's Avatar
Can you bridge the JL to run at 2 ohm?
Old Dec 4, 2006 | 11:28 AM
al503's Avatar
Max for each 10w6v2's is 400 watts rms, IIRC. You'll be fine with the 500/1, which is underrated anyway.
All you have to do is make sure that the input sensitivity/gain is set up correctly so the subs don't clip when you're really pushing them. Remember, doubling the power of the amp in general only yields a 3db increase in spl. That's probably 1 click up in volume. Not worth the extra money or the strain it's going to put on your electrical system.
I might also suggest the 10w7 instead of the v2's. It'll take up less space, and won't add so much weight with the huge enclosure you'll need for the 2 v2's. 1 sub (either the w7 or the w6v2) will be enough to create a bunch of buzzing/rattling. You'll probably want to dynamat regardless.
Old Dec 4, 2006 | 11:29 AM
al503's Avatar
the entire slash series will run fine at 2 ohms.
Old Dec 4, 2006 | 01:24 PM
BocaCoupe's Avatar
G's Up, Ho's Down
250watts is low for the 10w6v2, while 250watts is perfect for the 10w3v3
Old Dec 4, 2006 | 01:50 PM
I always figured the 500/1 was too much for a single 10W6V2 so I couldn't see running a 1000/1 for 2 of them...
Old Dec 4, 2006 | 03:47 PM
al503's Avatar
I bench tested my 500/1 a few years back. It was well over 700 watts rms. Some site or magazine test one a while back and they got over 700 watts also. It'll be fine for 2 w6v2's.
FWIW, I was powering a 12w7 with that 500/1. Got it straight from JL's national sales manager that I didn't need the 1000/1 and I that I wouldn't be able to tell much of a difference if I did.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
hrdwirk1
Oct 2, 2015 06:34 PM
