Navi to Video? Swap out Nav player?
Old Dec 9, 2006 | 12:19 PM
C_J_GO's Avatar
Is there a DVD/Nav player that could be swapped out for the Nav only player in the dash? I would rather not have to go install anothe DVD player somewhere else in my car...Let me kow what you think
Old Dec 10, 2006 | 01:41 PM
KPierson's Avatar
Not easily. You HAVE to keep the stock DVD player because it drives the screen directly. All the Navi info is IN the stock DVD player.
Old Dec 10, 2006 | 09:04 PM
GreenGoblin's Avatar
The goblin resurrection
would def not be cost effective to do something like that . I thought about possibly relocating the factory nav disk player to the trunk and put the dvd player where the nav goes
Old Dec 10, 2006 | 10:38 PM
Otacon132's Avatar
thats a really good idea - does anyone know if this may be possible?
Old Dec 11, 2006 | 06:38 AM
KPierson's Avatar
It should be possible, but keep in mind that there are about 30 wires on the back of the unit. The RGB-G signal would most likely benefit from using a shielded cable, while most of the other wires could use standard stranded wire.
Old Dec 11, 2006 | 08:08 PM
it is possible but im not sure if I wanna cut it up
Old Dec 11, 2006 | 08:40 PM
KPierson's Avatar
You may be able to hook up with NavtoGo and see if you can buy just the harnesses. I believe they tap in to both harnesses, so you could hack that up, and leave the OEM wiring untouched.
Old Dec 12, 2006 | 12:20 PM
digital1986's Avatar
x2 very good idea. I am going to have my installed look into it this week cause I need a spot for my xbox and if I take it apart it should fit in there
Old Dec 12, 2006 | 08:01 PM
very cool I am gonna have to call him
alessandro
Oct 8, 2015 09:29 AM
doakley92
Sep 25, 2015 12:58 PM
Joe Gargano
Sep 18, 2015 11:17 AM
