2 kickers and amp question...
Old Nov 12, 2003 | 10:59 PM
Aldo420's Avatar
I have 2 12inch L7.. what kinda of amp should i buy to power these babys well! looking for something not to expensive and reliable..
Also should i get a cap..
Old Nov 12, 2003 | 11:21 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: 2 kickers and amp question...
If you're just powering subs you can get by with a cheap amp. When you're dealing with low frequencies, watts are watts. So you don't need to spend a lot of money on some high-end name brand amp. Some may disagree though. You also shouldn't need a cap if you're not exceeding 500 watts. I'm guessing you're not because if you put 2 12s with more than 500 watts going to them with your factory stereo you're not going to hear much more than the bass. A cap isn't going to hurt your system at all and it can help the life of your battery. If you go with one the general rule is .5 farad for up to 500 watts and 1 farad up to 1000 watts.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, PS2, & TVs all up in the headrests.
Jax, FL
Old Nov 13, 2003 | 06:15 PM
Aldo420's Avatar
lol dude i was thinking 1200 watt amp each speaker peaks at 1500 watts ...
Old Nov 13, 2003 | 07:25 PM
infidsg35's Avatar
Peak and RMS are to totaly diffrent things. For those I wouldnt push any more then 750 watts each as there RMS is around there if I remember correctly. If you run 1200 watts each just say by by subs and like 600 beans down the drain.
I would probably go with the Rockford 1500bd and get ready to be def.. Its a VERY good amp and will run 750 by 2 @ 2 ohms
5 wire Grounding kit
350z Pipe / Stillen High-Flow
JUN Flywheel
Crawford Intake Manifold
Best 1/4 14.153 @ 99.19 / 2.29 - 60'
Old Nov 14, 2003 | 12:22 AM
limeg35's Avatar
RF's bd series are mono amps...750x1 @4ohm, 1500x1@2ohms, they are def a good choice...s.w
03 coupe 5AT DG/G premium,performance
Old Nov 14, 2003 | 10:08 AM
infidsg35's Avatar
Yea its a mono amp but when you take (2) 4 ohm subs and run them together it will be a 2 ohm load witch will make 750 by 2 on a 1500 watt channel.
Glad I got an answer for him as I am struggling with my oun
JUN Flywheel
Old Nov 14, 2003 | 07:15 PM
amg35's Avatar
Florida G35 Club
Consider the JL Audio 1000/1 amplifier.
Take care,
amG35
2003 Silver Sedan
Old Nov 18, 2003 | 12:17 AM
liquidforce13's Avatar
I have 2 10L7's with a zr1000 amp, works fine, and quadss seems like i can add another amp and it would be fine.
2004 G35c Black on Black/ 6mt/ premium/ aero
Old Nov 18, 2003 | 07:08 AM
ydlee's Avatar
Get a kicker amp. For amps at good prices www.ikesound.com
Old Nov 18, 2003 | 07:39 PM
Aldo420's Avatar
im sorry guys whats the diff betweens ohm's IE: 1 ohm 2 ohm 3 ohm 4ohm ?
Old Nov 19, 2003 | 04:54 PM
infidsg35's Avatar
resistance I believe. If a speaker is 4 ohms and have 2 then it is a 2 ohm load if bridged. If you didnt bridge then it would be a 4 ohm load. Then you got to see what your amp is rated at. If its 200 by 2 @ 4 ohms then if you bridge the amp it will be a 2 ohm load and will increase the power of the amp to 400 by 2. Make any sence??? Im sure there are some sound engineers out there that get a lil more technical..
JUN Flywheel
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
JustinMKN1
Sep 18, 2015 03:40 PM
