PAC SWI-X install ???
Old Jan 29, 2007 | 03:47 AM
DHCrocks's Avatar
everyone with the SWI-X, can you please post a pic of where you have the led installed. I'm trying to figure out where will be the best place for it that is hidden, yet still able to reach the deck.
Old Jan 29, 2007 | 03:38 PM
peteman's Avatar
SWI-X LED install
DHC,
I put the LED right where the arrow points but on the other side.
Careful drilling thru the aluminum!
Works great!
What head unit are you using?
Pete
Old Jan 29, 2007 | 06:16 PM
DHCrocks's Avatar
thatnks Pete. I'll be instaling a Clarion MAX675VD. So your led points straight up and it works ok?
Old Jan 30, 2007 | 12:23 AM
DaygoG35's Avatar
Make sure that your installer drills holes farther back on your bracket or your clarion will not sit flush. I need to have mine remounted. I'll do it when I get my tax refund check.
Old Jan 30, 2007 | 12:34 AM
peteman's Avatar
DHC,
I had a Eclipse 5495 and the LED location worked fine.
To be sure your Clarion can "see" the LED, you can program SWI-X, then hold the LED in a variety of locations, and test the steering wheel buttons.
My location should be fine if the IR pickup is close to the bottom edge of the unit.
Old Jan 30, 2007 | 12:37 AM
DHCrocks's Avatar
sounds good, I'll try moving it around and see where it works and is still somewhat hidden.
How far back should I drill the holes on the bracket?
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
