Help! Auto AC on, radio light off.
#46
I say yes to that. Cause if some of us here have changed radio's more then once and gotten the same problem again. There is something wrong with the radio. And I think they should be responsible for it. Its a radio, there are moving parts in there that for the most part are still working. However controls to make it work seem to brake. Its a panel and some circuit board somewhere in there that is dead. Change it fix it design a new one, whatever, but for what $2500 to get a bose system in there. It should last longer then the car.
#51
Hey guys! my problem with my radio/AC has been repaired. when i bought my G coupe i also got the extended warranty with it, all they did is replace the circuit board and it's fix. it's been a good 2months and it's not acting up so far. but my new issue is the passenger side window! sometimes its not rolling up, you have to bang! the door from inside so it will closed! but what the heck! still love the G!
#52
#53
#54
on
Mine started up last week again and was off and on. This week it's not working at all, but I was able to get heat and I can control the radio from the steering wheel, but the AC was still running.
I pulled both fuses for the blower (located on the driver side), the system came online again, but no air. I put one of the fuses back in for the blower and (knock on wood) everything is working normally again. It's been two days so far.
Probably not the correct thing to do, but at least it's a temp fix.
#55
#57
on
$#@!, this happens to my 03.5 sedan since a couple of months ago, after all these years?? The console display comes back on for a few seconds sometimes if I'm lucky in the beginning, then it went off completely now. a/c, radio are still working just can not change any settings anymore.
Any alternatives to $600 fix??
#59
same problem!!
hey all..... well i have tried unplugling the battery and that did not work.. but it reset my ac to 75 degrees alot better than 60 degrees where it was before.... i have checked all my fuses.. but i cant find the a/c relay on the car.. i heard replacing it might work.. but im not sure.. i want to try...today i took off center console to check the conections and the seem fine.. i unpluged the sterio and kept the AC conected and that didnt work.. so now im wondering what else can i do?? any one know how much are the double din dash kit??
#60
