Reverse Lights Fuse.
Old Mar 7, 2007 | 09:08 AM
schin101's Avatar
I was wiring my reverse camera and now my reverse lights don't work. Anyone know specifically where the fuse is?
I checked on the interior by the clutch and under the hood by the battery but didnt see anything I thought was the right one. Anyone know where it is?
Old Mar 7, 2007 | 12:17 PM
nyclifeg's Avatar
I had the same issue, the fuse is under the hood next to the battery. I do not remember the exact number but if you check one by one you will find it. I think its a red 15 amp. The manual will not tell you anything but that fuse is linked to other things as well.
Old Mar 9, 2007 | 09:31 PM
schin101's Avatar
I check all the fuses under the hood next to the battery no luck. Anybody have any other suggestions?
Old Mar 10, 2007 | 08:05 PM
KPierson's Avatar
What year is your car? Is it a sedan or a coupe?
Old Mar 11, 2007 | 02:47 PM
schin101's Avatar
It's an '06 Coupe.
Old Mar 11, 2007 | 04:36 PM
KPierson's Avatar
Fuse 83, its a 10A fuse in the IPDM (fuse box behind the battery)
There is also a Back Up Lamp Relay IF you have an AT, but it doesn't say where it is located.
You mentioned you have a clutch, so I'm assuming you have a 6MT so you would have ignition power going to the tranny on a Yellow/Red then green wire. Coming out of the tranny the wire is orange, then red then orange again and should be 12vdc when the car is in Reverse.
I would check the fuse first with a meter, sometimes they blow and you can't tell by looking at them. Then, I would measure the gray wire at the transmission with the ignition on and the green wire with the ingition on and the car in reverse. Should be pretty easy in this case to find the problem.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
youngdip631
Lighting
Aug 31, 2015 09:13 PM
ghost_g35
Aug 7, 2015 10:31 AM
