Infinity Kappa 653.7i - amp needed?
Old Mar 12, 2007 | 01:53 AM
clinthammer's Avatar
I still have 4 kappas 653.7i from my old car. Speakers are less than 1 yr old.
Can I install them in my stock audio system - do I need extra wires? Do I need an amp for them? I will get an audio place to do the install.
Infinity: Kappa 653.7i - 16.5/17cm speakers
* 3-way 6-3/4" (16.5/17cm) speakers (pair) * Plus One woven-glass-fiber woofer cone with hi-roll rubber surround * rotating UniPivot M.M.D. dome tweeter * computer-optimized outboard crossover with tweeter level control * power range: 2-75 watts RMS (225 watts peak power) * frequency response: 45-25,000 Hz * sensitivity: 95 dB * top-mount depth: 2-3/16"
Description: 165mm 3 way component speakers with loudspeaker and Emit super tweeter.
Old Mar 12, 2007 | 11:41 AM
16psibrick's Avatar
the kappa is bgest served with an amp yes...the reference set is the drop in set from infinity...
will the spekaer work if you just plugged it in? yeah it iwll make sound, but really, you ShoUld get an aftermarket amp
b
Old Mar 13, 2007 | 12:35 AM
so basically my audio shop will have to rewire the whole system from the stock HU to the new speakers to the amp?
Old Mar 13, 2007 | 01:23 AM
16psibrick's Avatar
in a sense yes...but for a good shop, it shouldnt be all that challenging i do it all the time for my customers
b
nettcar
Aug 25, 2024 11:59 PM
hdmark
Apr 29, 2019 04:31 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
Frostbite91
Aug 2, 2015 04:59 PM
Thunderaan
Jul 22, 2015 07:40 PM
