Stock bose system
Old Mar 20, 2007 | 08:26 AM
Crashtest77's Avatar
Stock bose system
Is there a sub in the stock bose system...03 g35c? I know it's nub question,but I don't know. Just curious where it would be located if there is one.
Old Mar 20, 2007 | 01:00 PM
drunkin master's Avatar
no.
Old Mar 20, 2007 | 05:22 PM
ty,now i need to come up with a custom setup for a sub.
Old Mar 21, 2007 | 10:02 AM
Gilley's Avatar
The 6x9's in the rear deck are what Bose considers to be subs. But they aren't subs as we all would consider one to be.
Old Mar 21, 2007 | 11:19 AM
Okies, I have something to replace those,and the rest,would like to put a 10inch sub in there,and just have a spot where it wouldn't be to noticeable.
Old Mar 21, 2007 | 11:23 AM
izmir41500's Avatar
G35driver Addict
you can go with the 4080 box or a box from zenclosures on ebay.
there is a 4080 box for the passenger and driver side behind the wheel well.
zenclosure box goes hehind the seat.
the 4080 is fiberglass and zenclosures are MDF i believe.
Old Mar 21, 2007 | 12:46 PM
Gilley's Avatar
I wouldn't put regular 6x9's in the rear deck. Just replace the front speakers and the side panel speakers. Add a 4080 box or Zenclosures box for a sub.
Old Mar 21, 2007 | 12:56 PM
Scootch's Avatar
only the sedans have a 8" sub or the 350z with its 10"
as for our coupes, someone has said it ruight the 6x9 on the rear deck act like subs but indeed are not
Old Mar 21, 2007 | 01:07 PM
Gilley's Avatar
The sedan sub is an 8 inch.
Old Aug 30, 2007 | 10:25 PM
MrPutzy's Avatar
I just picked up an 05 Sedan with the BOSE HU. I am trying to plan a stereo install/upgrade path, but am finding lots of conflicting info about what size speakers currently exist in the sedan. Can someone please sum it up for me?
When I replace the speakers, I will most likely put new components in the stock locations. It would be great to know what fits in each.
Also, I looked but can't find the stock AMP in my sedan. I saw some pics showing stock amp located next to spare tire. but now in my car, it is all trunk sheet metal around the spare.
I want to do a custom sub install in the spare tire well, and need to find room for the amp. I need my trunk as I need to put golf clubs in it frequently.
Thanks
Andrew
Thanks.
Old Aug 31, 2007 | 11:11 AM
Gilley's Avatar
6.5 inch components in front doors, 6.5 inch coax in rear doors.
The Bose amp in the sedan is in the trunk under the rear window. The coupe's Bose amp is to the left of the spare tire.
Amp placement is limited in the sedan if you want to keep the most available room and use the pass through in the rear seat. I mounted my amp on the floor of the trunk at the rear seat and built an MDF cover for it that is carpeted. It's protected from anything I throw on the trunk.
www.4080enclosures.com has a nice fiberglass enclosure for the sedan.
Old Aug 31, 2007 | 11:43 AM
lancer's Avatar
Clarion HU, you mean.
Keep in mind you will either need some 2 ohm replacement speakers to work with the Bose amp, or you will need to ditch the stock amp and go with regular 4 ohm speakers on an aftermarket amp.
Old Aug 31, 2007 | 11:44 AM
lancer's Avatar
+1 on the 4080 boxes, they are freakin fantabulous.
Old Aug 31, 2007 | 10:58 PM
MrPutzy's Avatar
I am thinking Infinity Kappa's (2 Ohm) front and back. Components up front and coax in rear. This will be my first change. Then I want to think about a sub. I am not sure yet if I want to replace the Bose HU, so I can do speakers and sub, with teh Bose, and reuse them if/when I replace the HU.
I like the look of the 4080's but I need to fit 2 sets of golf clubs in my trunk. So they are out for sure. I am thinking either a zenclosure with a single offset 10" sub, with amp mounted beside it. I have no need for the pass through.
Alternatively, if I can find someone in central florida (preferably east coast) that can do a decent job on building a custom enclosure in the spare tire well, I would do that. I saw one on one of the forums (done by Bing I think) where the sub enclosure was sort of 1/4 moon shaped, with space in front of it for the amp. With cover, you could put the normal trunk carpet down and have no idea that there was a sub under there. That would be perfect for me.
Andrew
Old Sep 1, 2007 | 12:55 AM
MobbinTehG's Avatar
I'm not sure if I could recommend the Infiniti Kappa components or not. I ran them for several months, so I have a good feel on their sound quality. The highs are very crisp and good for rap music, due to their metal dome tweeters (silk dome tweeters are more "natural" but its really a preference thing).
However, I found their midbass to be pretty lacking, even in a sound dampened environment. I never fiberglassed them their own little "enclosures" to test their performance in that type of an environment, so I couldn't comment on that. Midrange was okay, but I felt as though the response was not even from 1khz-3khz, although that could be vehical related.
If you are looking for a quick drop in solution that doesn't cost too much you will probably be fairly happy with them, but if your somewhat of an audiophile, you will probably be disappointed because they were pretty peaky in my experiences with them.
I did get mine for $40 shipped though, so its all good
