Warning about sound deadening and spray foam
Old Mar 26, 2007 | 03:00 AM
Meatshackle's Avatar
Deep Sea Moderator
Wow. That's a first.
Old Mar 26, 2007 | 04:13 PM
shibal_z's Avatar
I would recommend against spray foam applications if you can replace them using foam blocks to stuff into crevices and spaces. Drawbacks from spray foam is the unpredictability of the expansion as well as gradual deterioration over time in the form of foam powder and bits that sometimes fall out as things get loose. If using foam blocks, make sure that they do not promote the growth of bacteria as you will have an odor issue if it gets in contact with moisture/water.
Old Mar 26, 2007 | 04:19 PM
Hi-TechG35's Avatar
Wow thats crazy. Imagine if you had of gotten enough into the tailight it probally would've exploded.
Old Mar 26, 2007 | 05:06 PM
redlude97's Avatar
The problem is the trunk won't allow for foam blocks as the opening are tiny, and only allow enough room for the tip of the foam can.
Old Mar 26, 2007 | 06:41 PM
akavietboi77's Avatar
ur car is an sedan the coupe dont have wire in the trunk lid part unless u have a spoiler for the brake light
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
