Electical Problem
Electical Problem
i just posted about the LEDs in the headlights. well i took them out with a flathead and i must have touched the positive and negative terminals together. The amber blinker, headlight strip on the outside, and the amber bumper corners all went out. The low beams still work and if you press the hazard button the headlight ambers will blink. On the inside of the car if you switch the lights on, nothing dims, the dimmer dial doesnt work, and there are no amenity lights ie A/C lights, Navi lights, and the navigation screen doesn't dim. Has anyone had this problem, i really need help.
p.s. all the fuses are fine.
Thebaws11
Jul 2, 2021 11:36 AM
