double din question
Old May 3, 2007 | 01:01 AM
Mr_pharmD's Avatar
double din question
I have an 05 coupe with oem navi and bose system and I'm thinking of the kenwood 8017. My question is what else will I need?
I know I need:
1. JDM AC controller
2. Double din frame
Do I need the wire harness bc I have the bose? If so, which one and is there a difference?
http://www.installer.com/item/displa...php?it=70-7551
http://www.crutchfield.com/S-55uf3hi...display=XL#Tab
Old May 3, 2007 | 02:04 AM
Mr_pharmD's Avatar
also, i'm trying to keep stock speakers too... will I need to replace the speakers to work with aftermarket HU?
Old May 3, 2007 | 02:15 AM
imalazeeass's Avatar
sent uback a PM and no u do not need to replace your speakers. A lot of people just upgrade the headunit and leave everything else stock because the headunit itself can already make a difference in sound quality.
Old May 4, 2007 | 12:08 PM
Mr_pharmD's Avatar
thanks for the help imalazeeass.
Anyone running stock speakers and amp with aftermarket headunit and does it sound the same or worst then before??? Also, and hissing noice???
Old May 4, 2007 | 12:33 PM
ttrank's Avatar
Grocery getter
You don't have to change out the bose speakers but you will be shocked at how much better it will sound if you do.
Old May 4, 2007 | 02:37 PM
ON's Avatar
ON
I have the Pioneer Z1 with stock Bose system and aftermarket sub. Sounds a million times better than the original blose system. that Blose HU really sucks.
as for hissing...get a LOC (Line output converter)
http://scosche.com/scosche_caraudio....9&ItemID=SLC-4
It reduce the hissing dramatically.
you can find it at wal-mart for $20-$25.
Old May 4, 2007 | 10:32 PM
Mr_pharmD's Avatar
so will I also need this with the LOC?
Also, is the hissing noticable with it still?
Old May 4, 2007 | 11:00 PM
Gilley's Avatar
IMO, the first thing to replace is the Bose amp. That's the weakest link in the chain. It's short on power and adds unfavorable EQing to the sound, especially the bass.
Old May 4, 2007 | 11:17 PM
Mr_pharmD's Avatar
if u replace the amp u have to replace the speakers. Alittle too expensive. I am okay with the sound of the stock, just want a little blingbling in the car which I think it it lacks
Old May 4, 2007 | 11:38 PM
Gilley's Avatar
No, you don't have to replace the Bose speakers. You can do that later if you want.
But if you want bling more than better sound, then you're on the right path by just replacing the HU.
You will also need the Nissan diversity antenna adapter or your antenna won't plug into the back of your new radio.
Old May 5, 2007 | 12:07 AM
Mr_pharmD's Avatar
good thinking. Almost forgot about that.
Old Jun 14, 2007 | 07:25 AM
urbanlife's Avatar
So which harness do you need if you're going to keep the bose speakers?
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
Crappyday
Aug 27, 2015 10:26 PM
Frankieg35
Aug 15, 2015 10:49 PM
itztwinki3
Aug 1, 2015 12:58 AM
kd03g99
Jul 30, 2015 11:24 AM
