navi screen size
Old Dec 30, 2003 | 11:03 PM
icontractor's Avatar
navi screen size
Hey guys
anyone know what the screen size of the factory navigation is??
I need to know the exact size of the screen without the housing.
Anyone know
Old Dec 31, 2003 | 12:01 AM
Meatshackle's Avatar
Deep Sea Moderator
Re: navi screen size
The actual screen is 6.5" corner to corner. There is also a black border around the display that's another .25" on each side, then you reach the silver housing. So it's more like 7".
Russ
Black w/willow, 6MT Coupe, Nav, Aero, Nismo CAI, V1, PS2, AVelectronic Tuner, Headrest Monitors, Splash Guards..
Jax, FL
Old Dec 31, 2003 | 11:40 PM
RENNtech's Avatar
Here is the latest that I did... Pioneer "touch-screen" with navigation..
http://images.andale.com/f2/115/106/...5_DSC02736.JPG
<P ID="edit"><FONT class="small"><EM>Edited by RENNtech on 12/31/03 08:42 PM.</EM></FONT></P>
http://162779-http://images.andale.c...5_DSC02736.JPG
Old Jan 2, 2004 | 02:39 PM
shaf140's Avatar
thats what i wanted to do too but i was hesitant about having it be fixed and i wanted it to work similar to the stock instead.
is that the sys610t model? and have you tried playing a dvd movie?
Old Jan 4, 2004 | 03:56 PM
jdove's Avatar
I am about to install a custom car pc inot the "nav pocket" and a Liliput (similar to Xenarc ) 7" XGA monitor into the "display pocket" . I really just want to remove the "lid".
I don't have a factory nav , and its a G35C.
Is there a way to remove it without removing the entire center facia , or is it screwed in from the back? The service manual is unclear how this lid mounts to the facia. Since you added a display of similar dimnesion,. I figure , you have had it all apart.
Thanx.
Old Jan 4, 2004 | 04:48 PM
aorbeta's Avatar
You have to remove the dash to get to the lid. If you're installing a car pc anyways, you might as well get some practice removing/installing the dash. Takes me about 5-10 minutes to get the center section with the radio and ac out. The pocket and lid assembly is screwed in from the inside. The lid can be removed from the pocket, there are spring loaded pegs on either side of the lid that attaches it to the pocket.
Old Jan 4, 2004 | 07:45 PM
aorbeta do you know of any touchscreen monitors that will fit in the stock monitor housing
Old Jan 4, 2004 | 09:25 PM
aorbeta's Avatar
None that I know of without modifying the stock monitor housing. Although, I don't know about the size specs of the Xenarc or Lilliput if you disassemble them. The digitallww.com one doesn't fit without messing with the stock housing.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
yosip1115
Sep 9, 2015 03:30 PM
Detailed Image
Sep 4, 2015 08:35 AM
