HELP! ALMOST finished installing new sub and amp, need instruction on wire splicing
Old May 8, 2007 | 10:52 PM
wuyichao's Avatar
i have a bose system
i've ran the power cable from the fron to my rear trunk
i've connected the ground wire to the car's chasis.
now i need to splice the wire coming from the speaker, and tap them into the new rca line, any detail instruction on how to do that? i know what wires that i need splice, i just want to know how to splce them...i really need to get this done, but i doubt my wire splicing skill...
so please help!
Old May 8, 2007 | 11:27 PM
Gilley's Avatar
When you say speaker wire, I hope you mean brfore it goes into the Bose amp.
To splice the wires, cut them, strip a little off the end and either twist the wires together and solder them or use butt connectors.
Old May 8, 2007 | 11:38 PM
wuyichao's Avatar
yes im gonna tap them b4 they go into the bose amp
so u mean stripe them and connect the rca cable to these 4 wires, and these wires dont have to go into the bose amp??
Old May 9, 2007 | 12:41 AM
Meatshackle's Avatar
Deep Sea Moderator
The speaker wire should be going from your new amp to your sub.
You should be stripping the input signal from the head unit, before it goes to the amp, and splice in the other end of the RCAs that will be going to your amp to that.
Old May 9, 2007 | 12:48 AM
Sponger's Avatar
6MT Brembo Coupe
I posted instructions in the other thread you started.
Old May 9, 2007 | 01:46 AM
IP G's Avatar
use t-tap
Old May 9, 2007 | 12:43 PM
wuyichao's Avatar
i know which wires to splice and tap, its the speaker wire coming from the boss speakers to its amp. and i know the four's colors.
its really my first time doing this electronic thing, i've done everything else, except i need to splice them, and i dont know how, whether i need to cut them in to halves, or i need to take one end off from the gauge and strip a little off, then just twist the new wire in the middle of the stripped wire.
thanks for all the replies!
Old May 9, 2007 | 02:40 PM
Gilley's Avatar
No, those are the speaker wires coming out of the Bose amp. They have already been amplified and you don't want to connect them to RCA cables and feed them to your new amp.
You want to tap the wires going into the Bose amp before the signal goes into the Bose amp and gets EQed and amplified. Those wires are at line level of about 2 or so volts, which is safe to feed your amp.
Old May 9, 2007 | 07:36 PM
Deep Sea Moderator
+1
The only speaker wires you should be working with are the speaker wires going from your new amp to your new sub.
You need to tap the SIGNAL wires from your head unit before they go into your Bose amp.
Old May 10, 2007 | 01:05 AM
wuyichao's Avatar
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
