How do you remove the shifter?
Old Jan 2, 2004 | 07:45 AM
g35funk's Avatar
I've seen the posts for removing the dash assembly, but it was for a manual trans. To get to the dash on my auto trans. I need to remove the shifter but don't know how. On my Land Rover you simply put the car in D, then pull up on the shifter. I tried this on the G but it didn't work. Anyone know how to take this off?
Thanks...
Old Jan 2, 2004 | 08:52 PM
mstil35's Avatar
Re: How do you remove the shifter?
Slide the plastic cover on the bottom of the shift **** down. You may need a small screwdriver to do this but be careful not to scratch anything. With the cover out of the way, look for a small brass or copper clip. It is round on one end and open on the other and is installed arouund the shift ****. Use the screwdriver to gently pry it out and then simply lift offf the shift ****...but be careful when you take the retainer clip out because it may pop out and be lost. If you have any trouble, PM me.
Old Jan 3, 2004 | 05:24 PM
g35funk's Avatar
Cool. I'll give it a try. Thanks for the info mstil35.
Old Jan 3, 2004 | 06:26 PM
G35Newbie's Avatar
Instruction is on the DIY FAQ .
Mod: Borla exhaust / Nismo sway bar / Z duct / Amsoil air filter [img]/w3timages/icons/laugh.gif[/img]
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
