Best JL 250/1 amp install location?
Old Jun 6, 2007 | 04:41 PM
fishmd's Avatar
Originally Posted by Steel Blue
anyone mount it upside down to the rear deck? At least it is open air.
I would be interested in that too. Seems like this would be a bit better than inside the spare tire. Maybe I will take a look at that way, although I would probably have to build a shelf back there for the amp to hold it in place, or clamps or something. I don't know.
Old Jun 6, 2007 | 07:24 PM
Boostedef's Avatar
dude why are you stuck on mounting it upside down make some brackets out of some metal strips that you can get at home depot for like 3 dollars and mount the amp the right way. As stated heat rises thats why the board is the lowest point on the amp and the heat sinks (the black part on the side of you amp )are what move the heat up and out. So if you mount it upside down with your heat sinks facing down and heat can only rise ,,, what happens ? Your amp will keep turning off untill one day it just blows and youll mount the amp the same way and it will be a cycle untill the world ends lol
Old Jun 7, 2007 | 12:38 AM
amthar's Avatar
mine is mounted on top of the bose bracket, I modified the black trunk support at the previous poster mentioned. I have been running it like this for over a year now with awesome success. A razor blade and some industrial strength velcro works wonders. And I'm running a 500/5... much bigger beast to fit.
Old Jun 7, 2007 | 11:14 AM
lancer's Avatar
Which if I remember correctly is the same chassis as a 1000/1.
Old Jun 7, 2007 | 02:01 PM
amthar's Avatar
ya i believe so
Old Jun 7, 2007 | 02:57 PM
fishmd's Avatar
Any pics by chance of the install showing the cutout?
Old Jun 7, 2007 | 04:49 PM
lancer's Avatar
ya i believe so
wow nice setup btw, I wanna see some install pics of the rest of it as well.
how do you like the dls? My friend has a set of iridium 6.5" components, I've considered buying them from him a few times.
Old Jun 8, 2007 | 08:40 AM
amthar's Avatar
https://g35driver.com/forums/attachm...1&d=1143233301
This shows the side "window" I cutout so that the corner of the 500/5 can stick out. Other than that, if you flip the black support upside down you'll see plastic "fins" that come down, I had to remove those so the top of the amp sits flush against the top of the support.
I'll try and take some more pictures this weekend.
Old Jun 8, 2007 | 11:04 PM
fishmd's Avatar
cool, thanks for the pics. It helps to see it.
Old Jun 8, 2007 | 11:36 PM
Gilley's Avatar
Mine is cut like that for when I had my JL 500/5 there.
Old Jun 11, 2007 | 07:27 AM
fishmd's Avatar
Bump
Old Jun 16, 2007 | 04:54 AM
MechEE's Avatar
Originally Posted by Boostedef
correct me if Im wrong but that would let your amp heat up to much. I mounted a RF amp I had upside down under the rear deck on my 330i
and it would get hot and clip every 30 min or so and one of my friends who works at a stereo shop told me it was because of that
I had the same concerns, but given the low power level of the 250/1, I decided to just give it a try. I've yet to have the amp turn off on me, even in scorching summer temperatures.
Old Jun 17, 2007 | 02:15 AM
lancer's Avatar
allow me to quote the old addage that "install is everything".......
hdmark
Apr 29, 2019 04:31 PM
Team STILLEN
Aug 10, 2015 08:17 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
Thunderaan
Jul 22, 2015 07:40 PM
