Backup camera recommendations
Old Mar 5, 2010 | 10:52 AM
  #121
shdowflare's Avatar
Do you guys know if any universal backup camera will work with a stock navi on a 1st gen sedan?
Old Mar 6, 2010 | 07:29 AM
  #122
tom's_Z's Avatar
^^You'll need tvandnav2go to use a camera on a stock setup. Look it up via google, their shop is in NY. I got mine for 200 picked up and it is plug and play. All it is is a unit that interfaces with ur stock screen to allow for video playback. It has 2 inputs, one for the backup camera and one for regular viedo input. You will still need a pa-11 unit if you want sound for the second video source. I still have it even after I upgraded to a double din-I wanted a dual video screen and I like the reverse cam to show on the nav screen since it is higher up....anyway I use an eBay ccd NTSC camera, the small round one u drill into the bumper to install. Small discreet and an excellent pic, cost 105 shipped. Avoid CMOS cameras because the picture is inferior.
Old Jun 8, 2010 | 06:33 AM
  #123
bangooface81's Avatar
hope someone can help me with this issue.
im close to purchasing a 2007 g35 sedan sport, but it doesnt have the coveted back up cam. im wondering if its possible to install a backup cam thats identical to the factory issued version, and how much im looking at spending. need to make a decision in the next 6 hours, much thanks for any input.
-e
Old Jun 8, 2010 | 07:48 AM
  #124
Wrathernaut's Avatar
Gentle Manne of Leisure
I don't know about coveted, the sedan has good enough rear visibility that it's not that big of a deal.
The only camera identical to the stock one is the stock one. To add it, you'll need at the very least:
Chrome trunk lip piece
Camera
(possibly) trunk button
Harness
The other problem runs into whether the non-backup cam a/v/info unit works with the camera or if you'd have to replace that as well.
The simpler stock-look solution?
Relocate or go without the trunk button, and get a small camera (there's a surprisingly large amount of room where the stock trunk button went) that fits in there. Use your mounting method of choice ("Sculpy" clay would probably work well here) and run through either the stock video in RCA jack (modded to display video while in reverse).
Old Jun 8, 2010 | 09:32 AM
  #125
blAk mAx's Avatar
yOu could always put in a carPC . That will cover your movies, music, gps, wifi, games and cameras
Old Jun 8, 2010 | 12:46 PM
  #126
thanks for your help guys.
well, i just purchased it. 07 G35S sedan. its my first nissan/infiniti....i hope it meets my expectations! Im going to look into the aftermarket rear cam replacing the trunk button option. i called the dealer and they told me that its not possible to install the cam or sensors unless it came with the car from the factory. bummer.
well, thanks again!
-E
Old Jun 8, 2010 | 01:23 PM
  #127
I looked into the trunk button-hole camera on my buddy's 07. Kenwood makes a small one, and if you look for "keyhole" cameras, they will likely fit in there too.
Old Oct 13, 2011 | 10:18 AM
  #128
buzzking's Avatar
Is there a backup camera that'll hook up to the oem 05 nav screen?
Old Oct 13, 2011 | 12:18 PM
  #129
See a few posts up:
https://g35driver.com/forums/4931703-post122.html
You'll need an adapter more expensive than a standalone screen to make it work.
Old Oct 13, 2011 | 01:20 PM
  #130
buzzking's Avatar
Which back-up camera did you get exactly?
You seem very happy with your model and I would like to get the same!
Old Oct 13, 2011 | 01:25 PM
  #131
buzzking's Avatar
Originally Posted by Wrathernaut
See a few posts up:
Thanks for the info.
I didn't know it'll be more expensive to use the backup camera on the oem nav.
I will consider a standalone screen as well.
I was thinking of getting the tvandnav2go.
Do you recommend anything in particular as far as standalone screen and/or backup camera?
Old Oct 13, 2011 | 04:17 PM
  #132
No, no recommendations, I've never found one necessary for backing up, and don't have to worry about impressing high school kids with different things to put on a screen in my car. Just check reviews on amazon for which ones do well.
f22raptor
Mar 18, 2016 08:50 AM
dseet
Oct 11, 2015 12:40 AM
RWDguy4238
Sep 30, 2015 12:13 AM
Detailed Image
Sep 28, 2015 07:04 AM
