Wierd problem with Alpine IVA W205 install
Old Jun 10, 2007 | 12:06 PM
deckdout2's Avatar
Wanted to see if you guys might possibly be able to help out. Just installed this with the TR-7 and PAC JACK. Below is what occurs currently.
- Turn car to ON position, everything works fine.
- From that point, proceed to start vehicle, Alpine does not work. Blank screen, and after 15 or so seconds, the screen comes back, but no functionality.
- What could possibly be the issue here?
2nd Scenerio......
- From OFF position, proceed to fully start the car, without pausing at the, "ON" position, and everything works fine.
- Is this because of the TR-7 or another cause?
Cliffs: If I stop at the ON position, hu works, if I start the car from there, it stops working. If I don't stop at the ON position, and I just start the car from the OFF position, it works fine.
Any ideas, and where's this how-to that everyone keeps talking about for the PAC-JACK install. I can't get it to take any of the steering wheel programming functions. I'd like to see a diagram of the install if anyone has one. Searched but, there was no luck in finding my answer for this.
Thanks for your help.
-p
Old Jun 10, 2007 | 12:28 PM
g35rcr's Avatar
its the tr7 thats causing your problems...take it out and just wire up a bypass to the hand brake
Old Jun 10, 2007 | 11:15 PM
jryanwilliams's Avatar
could you elaborate? what wire to use to make the bypass? I have the same issue
Old Jun 11, 2007 | 12:30 PM
g35rcr's Avatar
the one that goes to the hand brake you can send it to a pulse switch and ground it...works the same way as the tr7 but you just have to click it on/off each time you want to bypass the system
Old Jul 28, 2007 | 12:45 PM
G-Ryda's Avatar
The TR7 has a programable delay of up to 4 minutes and 15 seconds before turning off/on... You should look into how to remove the delay
chinee
Jun 10, 2024 07:48 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
saskicker32
Aug 11, 2015 02:12 PM
chinee
Aug 8, 2015 10:11 AM
attarday
Jul 15, 2015 04:03 PM
