Help reprogramming remote key fob
Old Jul 20, 2010 | 07:02 PM
  #31
Subs's Avatar
Thanks so much, Now that I know that I will take it in to get looked at. You guys rule Thanks Wrathernaut
Old Jul 21, 2010 | 02:49 AM
  #32
Wrathernaut's Avatar
Gentle Manne of Leisure
I hope it's that simple, good luck.
Old Oct 20, 2010 | 07:09 PM
  #33
jaycuzz1's Avatar
does anyone know if this will work on a 2006 g35 sedan
Old Nov 7, 2010 | 06:48 PM
  #34
shawnhale05's Avatar
I only have 1 remote for my g35 sedan. If I buy another remote off of ebay and do this to reprogram both remotes for my car, will this also work for starting the car?? I have the ignition where you just need the remote in the car and you can turn the **** to start it.
BTW just bought this car used a couple day ago and only came with 1 key that will start the car. The other two keys work on the doors, but they won't start the car. I think they need the chips in the reprogrammed or something. Anyone have a good way of doing that without paying the dealer to do it? Can a locksmith do it? Thanks!
Old Dec 8, 2010 | 08:39 AM
  #35
sekh's Avatar
Purchased a used OEM key fob off eBay a few days ago. Tried the reprogramming method outlined here and it worked first try. Thank you everyone who contributed and g35driver.com
Old Dec 17, 2010 | 08:50 PM
  #36
xeroglock's Avatar
by the way this sounds iam wondering dose this mean you can also use a 350z FOB to program to a G35 or am i wrong?
Old Jan 25, 2011 | 11:41 AM
  #37
joncunanan's Avatar
i just received my spare fob from ebay yesterday.
when i program this new fob, does it clear the programming for the one i currently use?
Old Jan 30, 2011 | 11:23 PM
  #38
jaketuff's Avatar
All right this is how it worked on my 05 G35 Coupe...
Everything same as other posters EXCEPT!!! ....
1. To start the process properly you need to open the door
2. Close door (door lock remains in unlocked position)
3. Use powerlock button to lock the doors
4. THEN THE RYTHMN needed to get the 7 needed key entries and removals to flash the lights is easy as pie.
I was able to get the hazards to flash sitting in the car and unlocking it and locking it a couple of times... but it doesn't clear the code for some reason at that point. And also make sure that your battery is un correctly, with the + sign facing DOWN in the fob, the + should face the plastic.
Once I realized the open close door then lock, this was cake.
OUT
Old Mar 7, 2011 | 09:19 PM
  #39
Deep Dish V35's Avatar
My Japanese spec 2001 V35 sedan (same as US 2003 G35 sedan) has a similar problem to others.....
Power lock button does not lock drivers door.
Insertion of key 6 times does nothing.
When locking doors via drivers door lock, insertion of key 6 times just unlocks car, no flash of lights.
This is obviously why a previous owner had an aftermarket central locking system fitted. And yes, all of that system has been removed and returned to standard as the remote was lost....
If my Nissan dealer can do the computer hookup and reprogam for free, i'll try that...... for $150 i'd rather install a proper immobiliser
Old Mar 18, 2011 | 01:55 PM
  #40
jookyshank's Avatar
I haz hugz to givez
Sub'd for later use
Old Apr 2, 2011 | 04:15 PM
  #41
HotRedG35's Avatar
Unhappy extreme fob programming issues
Alright, I have tried all of the above and have only made matters worse.
I recently bought a fob off ebay for my 2003 G35 Coupe, as it only came with one when I bought the car last month.
I followed the directions above, and got as far as step 4. I pushed the button on the fob and it registered, I went to do the next one and something went wrong. Now neither fob works and the alarm cannot be deactivated.
Every time I do anything with the car, whether it's open and closing the door or starting the car, the alarm goes off. But the weird thing is, I can still start the car and drive it with the alarm going off.
My husband disconnected the alarm sound, so we don't need to deal with the sirens, just an irritating clicking sound.
I think the answer is to disarm the alarm and trying to program the fob again, but we can't disarm it without the fob. Is there another way of doing this?
Or is this something I'm going to have to take to the dealer?
Please help!!
Old Oct 7, 2011 | 04:47 PM
  #42
Monkey74's Avatar
Quick question, will this method work on the 2008 since you don't have to put the key in the ignition?
Old Feb 9, 2012 | 02:51 PM
  #43
badboyshayne's Avatar
06 g35x new key
i have a new key from and ive tried programing it myself by using u guys sugestions but have not been sucessful.does anybody have any answers?
Old Feb 9, 2012 | 04:20 PM
  #44
dukehotty's Avatar
If you have the Intelligent Key Fob, you will have to take it to the dealer so they can program it for you. If you have one already and are adding another, you will have to have both programed together.
Old Feb 14, 2012 | 09:20 PM
  #45
Buddy_Bodean's Avatar
I bought a 2004 G35 Sedan yesterday with 1 key and 0 fobs. I reprogrammed (2) 2007 350Z fobs to work using these instructions. Yeah for me.
F*uck You! dealer programer and your expensive charge.
--- My First Post! --
