Nav relocation / dvd player edfc install
Old Jun 21, 2007 | 12:06 AM
GreenGoblin's Avatar
The goblin resurrection
Hey I though I would share with you guys the idea that I had was to move the nav rom under the seat because you never take the cd out almost ever, and utilize that space for a dvd player and other goodies so that the car looks 100% stock. This is not that easy of a project but I am going to give you guys a play by play. I requires good electrical skills Ie. Soldering, cutting, clean wire layout ect.
The first step is to unhook you battery I did a lot of cutting, soldering, and extending.
The next step I took out the seat so that I would not damage it and easier to run wires later.
strip the dash area to get the dvd rom out and gain access to all areas of work.
These are all the wires and connectors that we will be cutting and extending I think it was about three feet but dont hold me to it.
This was the only difficult cable because it has a insulation wire and a regular wire in the middle.
shave back the shielding cable then twist that up and stip the cable in the middle essentially making two wires out of the one.
here is a shot of the shielded cable and the ground I believe extended.
There is no turning back here also go one at a time or mark the wires there are a couple wires that are the same color so pay attention.
These are some shots to show how many wires you are dealing with here it is a lot but be patient and know what is what and it will come out great.
Here is the almost factory looking extended harnesses.
Here a pulled the carpet back so that I could route the wires where all the wires for the seat come out.
plug the dvd rom in and you will be good to go
Old Jun 21, 2007 | 12:14 AM
Next part what I did with the opening
I reused the bracket that hold the dvd rom up in the upper glove box with some modifications.
here is the new dvd player mounted and ready to go. with the plug for the edfc all wired up ready to be plugged in.
This is what it looks like with everything in there mounted up. I still need to make a finisher piece to cover the gaps on either side. I think I will use some black plexi.
a shot of everything working ( super troopers is on the screen)
a shot of the edfc at night
the upper glove box closed to show the factory look when everything is hidden
and last but no least the push button start out of an s2000
all and all this was a pretty time consumuing project I did it over 2 days and it was raining both days so not sure now many times I started and stopped but I am very happy with the results. Post some comments and tell me what you think.
Thanks
Danny
Old Jun 21, 2007 | 12:25 AM
cipriopt's Avatar
Does the red button work? It says ENGINE START
Old Jun 21, 2007 | 12:55 AM
yes it is a push button start out of an s2000
Old Jun 21, 2007 | 08:10 AM
myG35ZX's Avatar
Is the key required?
Old Jun 21, 2007 | 10:57 AM
yes it is just like the ferrari 's but key in to the on possition then press start
Old Jun 21, 2007 | 11:24 AM
JAYY-G35's Avatar
Ahh Great Work, But I Rather Take It To A Shop To Do Lmaoo.
Job Well Done, I Wish You Was Out Here In Cali. I Would Of Let You Handle All Of The Dirty Work Lol.
I Was Planning On Doing The Same Thing To My 2003 G35 Coupe.
Put The Dvd Player In, And Relocate My Nav
Old Jun 21, 2007 | 12:02 PM
Augy's Avatar
thats tight! good job man!
Old Jun 21, 2007 | 12:15 PM
izmir41500's Avatar
G35driver Addict
wow that's a lot of work. good stuff. someone spilled some crap on your carpet.
Old Jun 21, 2007 | 01:41 PM
i know atleast after I got to clean it real good b4 the seat when back in
Old Jul 27, 2007 | 10:50 AM
BlackG171's Avatar
Florida G 35 Club
Very nice install...
Old Jul 27, 2007 | 11:00 AM
thank you very much
Old Feb 6, 2008 | 06:29 AM
Chris Rogers's Avatar
does it generate errors. the two bits on shielded wire you cut are DATA lines that run some of the car.
Old Feb 6, 2008 | 08:24 AM
no sir no errors what so ever
Old Feb 7, 2008 | 11:30 AM
G-Rated's Avatar
nice work man looks stock which is always good.
