Cigrarette lighter wiring, inverter Q's for my PS2 install
Old Jul 13, 2007 | 07:33 AM
  #31
Meatshackle's Avatar
Deep Sea Moderator
Good choice. Standard relays are 30amp. If you're using a switch there's no reason for a relay. If you want to wire it off of the battery and use the relay then you won't need the switch. The relay is just an automatic switch.
Old Jul 13, 2007 | 10:19 AM
  #32
shdowflare's Avatar
Here are my two requirements:
1. Prevent my dumb@$$ from forgetting to power off the inverter (since it'll be directly wired to the battery). I believe I need the relay here so power only gets on the inverter circuit when my vehicle is running.
2. Only have the inverter actually running when I want to play PS2. So I need the second switch to manually complete the circuit when I want to play video games.
My understanding was that I needed both trelay and switch to accomplish each task above.
So you guys think the 200w/25 amp inverter isa better choice then? I imagine I should still pull right off my battery or an empty terminal in my fuse box since the cig lighter circuite is only rated at 20 amps.
Thanks.
Old Jul 13, 2007 | 10:40 AM
  #33
Gilley's Avatar
I completely agree.
Thanks.
You will need a switch and a relay if you want to make sure it turns off with the car and is only on when the car is running and you want to use it. I would run it straight to the battery and put a fuse close to the battery.
Old Jul 13, 2007 | 12:51 PM
  #34
shdowflare's Avatar
Sounds like I have my plan now. Thanks guys for all the help getting me to this point. Truly appreciate it.
-B
Old Jul 13, 2007 | 07:11 PM
  #35
shdowflare's Avatar
Final design
Here's the final design as I see it. Take a look and let me know if everything looks good or if you have any suggestions:
Old Jul 13, 2007 | 09:19 PM
  #36
Gilley's Avatar
^ The diagram looks good to me. Nice job.
Old Jul 13, 2007 | 09:46 PM
  #37
shdowflare's Avatar
Thanks again. I'll let you know how it goes.
Old Jul 14, 2007 | 02:05 AM
  #38
Deep Sea Moderator
Looks good. I good place for the relay is behing the passenger kick panel. There's tons of empy space there. There's also plenty of room behind the passenger 12volt outlet panel.
Old Jul 14, 2007 | 09:34 AM
  #39
shdowflare's Avatar
Where's the passenger 12v outlet panel?
Old Jul 14, 2007 | 02:16 PM
  #40
Otacon132's Avatar
i havent read through, or know 100% wqhats going on, but figured id show you where i placed my switch's to give you an idea if you needed, may be too late:
i have 2 there now, right under that one is the 2nd
and for my bass (i dont really like that big blue thing i might get a different one soon)
Old Jul 15, 2007 | 10:32 AM
  #41
shdowflare's Avatar
I like where you placed your switch in the first picture below. I'll probabaly do the same. Where'd you ground your lighted switch on the bottom pic?
-B
Old Jul 15, 2007 | 01:10 PM
  #42
Otacon132's Avatar
some random bolt/screw i found up near the clutch area i think
Old Jul 15, 2007 | 02:00 PM
  #43
Deep Sea Moderator
There's a lot of screws in the console that are good grounds. I checked almost every metal screw in the center console with a multimeter.
Old Jul 15, 2007 | 03:11 PM
  #44
GreenGoblin's Avatar
The goblin resurrection
yup I did the same when I was doing my nav mod.
Old Jul 15, 2007 | 05:13 PM
  #45
shdowflare's Avatar
Good information...I was going to ground my switch and relay to the cig lighter ground wires just to be safe. But it sounds like there are much closer grounding points to where those devices will actually be mounted. The only reason I was going to do this is because I tried grounding my PAC SWI-ECL to a bolt under the steering column and it was causing the device to malfunction. Guess I should get a multimeter and test whatever I plan to use as a ground (just to be sure).
-B
There's a lot of screws in the console that are good grounds. I checked almost every metal screw in the center console are with a multimeter.
