Cigrarette lighter wiring, inverter Q's for my PS2 install
Old Aug 14, 2007 | 12:11 AM
  #46
shdowflare's Avatar
Hey do you guys know where I can tap into a constant 12v source, maybe a fuse box terminal or elsewhere? I want to rewire one of my cigarette lighters to remain on when my car is off so I can charge my phone without having the key in the ACC position...
Old Aug 14, 2007 | 01:55 AM
  #47
Meatshackle's Avatar
Deep Sea Moderator
Yeah that's nice to have. I re-wired one of mine and put a switch on it. I didn't use the fuse box though, straight off of the battery.
Old Aug 14, 2007 | 07:42 AM
  #48
Gilley's Avatar
A test light or multimeter can be your friend at the fuse box. It will tell you which fuse circuits are switched.
Old Aug 14, 2007 | 10:53 AM
  #49
shdowflare's Avatar
I suppose I could just run it off the 12v line I'm using for the inverter, but just tap the cig lighter into the line before the relay? Or do you guys think it's best to reserve that entire line for the inverter?
Old Aug 14, 2007 | 11:10 AM
  #50
Gilley's Avatar
The phone charger uses little amperage, so you would be fine using the same line as the inverter. Just don't run high amp things in the cig lighter at the same time the inverter in turned on.
Old Aug 14, 2007 | 06:03 PM
  #51
shdowflare's Avatar
Hey what can I use to connect two 10g power cables or a 10g and 12g wire together? Should I just use a butt crimp connector?
Old Aug 14, 2007 | 10:09 PM
  #52
Deep Sea Moderator
That's pretty small so you could butt crimp them or solder and tape.
Old Aug 16, 2007 | 10:38 AM
  #53
shdowflare's Avatar
And I've been trying to hunt down some 12g power cable with little luck. No one seems to stock it...tried Radio Shack, Best Buy, MyerEmco, etc. Any ideas where I can get about 10-15 ft of 12 gauge cable for my relay?
Thanks...
Old Aug 16, 2007 | 11:16 AM
  #54
Gilley's Avatar
12 gauge speaker wire will work.
Old Aug 16, 2007 | 11:48 AM
  #55
shdowflare's Avatar
Thanks man.
Old Aug 19, 2007 | 06:30 PM
  #56
shdowflare's Avatar
hey guys
Just installed the inverter and PS2 today. I'm getting no video and a loud audio interference. If I pull out the yellow composite video cable the noise stops.
Any ideas?
Thanks,
B
Old Aug 20, 2007 | 10:50 AM
  #57
shdowflare's Avatar
Figured it out...stupid error of mine. Anyway thanks for the help.
EnCr1pt3d
Jul 8, 2019 02:48 PM
willdogs
Dec 8, 2015 11:32 AM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
beevanhuynh
Jul 14, 2015 09:06 AM
