Problem with AC! Blowing Ice Cold, Little Heat
Old Jul 23, 2007 | 11:39 PM
VancouverG88's Avatar
Hey everyone! I'm having a problem with my AC in my car. Note I am in Canada so I am using metric for temperature.
Everything has been working fine recently, but today I noticed that my air conditioning was starting to malfunction. With the AC button lit, I observed the following:
18°C - Unbearable, ice-cold air blowing out. Normally it is bearable.
20°C - This is what I normally leave the temperature at, and it is comfortable. However, the air coming out is extremely cold, only slightly warmer than at 18°.
25°C - Normally, this temperature setting is hot, used for defogging windshield, etc. However, now it blows mildly cold air. Very little hot air is coming out
28°C - This is where things start to get interesting. The air blowing out suddenly goes from very cold to extremely hot.
<Note that the temperatures set can be adjusted from 18°-32° in Canadian models>
I first suspected that an AC line under the hood was damaged or leaking. I've included photos below, but it doesn't appear to have any damage. Please help!! I have not installed a Z-tube or any other type of intake mod.
-Thanks
Old Jul 24, 2007 | 02:48 AM
imalazeeass's Avatar
no more warranty?
Old Jul 24, 2007 | 03:02 AM
tomparker22's Avatar
Originally Posted by imalazeeass
no more warranty?
+1
warranty?
Old Jul 24, 2007 | 05:16 AM
I THINK the warrenty has passed. Any ideas what happened?
Old Jul 24, 2007 | 05:17 AM
Will dealerships/stealerships even cover the air con? my local stealership always tries to cheap out and avoid paying for anything.
for now, i'm just running the car with no AC or fan, in case there is a leak or something. open windows = temporary solution
Old Jul 24, 2007 | 09:45 PM
its an 07? it doesnt have the full warranty?
Sorry i have no idea
Old Jul 25, 2007 | 06:50 AM
g35rcr's Avatar
there is a sensor on the panel below the steering wheel that controls the air temp...on the panel it looks like a small rectangular grill, sort of like a mic panel. take the panel off and check to see that the tube and sensor are plugged into that...i forgot to replug mine when i worked on my stereo, 1 deg up from cold would make it full hot...
Old Jul 25, 2007 | 11:10 AM
erdog's Avatar
^^Same here.
Old Jul 25, 2007 | 07:31 PM
i haven't played around with anything under the steering column, but it's worth a shot. will check later today, studying for physics right now.
btw, its an '04 g35x
Old Aug 1, 2007 | 02:58 AM
g35ATX's Avatar
Have you checked your coolant level?
champppy
Mar 31, 2020 12:25 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
All G'd Up
Aug 29, 2015 12:40 AM
Smittie20
Aug 9, 2015 04:29 PM
