Check Disk error in Bose Unit
Old Jul 29, 2007 | 08:06 PM
A6Driver's Avatar
I was traveling last week and my CD Player Quit! It is a 2004 Sedan non-nav unit with 50K miles. All I get now is a "Check Disk" error on the display. I have tried to reset the unit (read as power off) and everything works except the CD Player. Has anyone else had this problem. I have checked the posts and all I can find is head unit faults. Could this be one of those?
Thanks! Chris
Old Jul 29, 2007 | 08:51 PM
SCoupe's Avatar
A fairly common problem with the cd in just about all G's.
Old Jul 29, 2007 | 10:27 PM
TIRE_SMOKE96's Avatar
+1 on last comment
Old Jul 30, 2007 | 12:22 AM
A6Driver's Avatar
How to fix it?
Does anyone have any suggestions of how to remedy the situation?
Old Jul 30, 2007 | 02:37 AM
soaped's Avatar
if you are out of warranty,
spend about 280$ for the oem double din parts, and get an aftermarket headunit.
or find a good bose unit off ebay.
the dealership will rape you on costs ($1500+).
If you are in warranty:
the dealership will replace it for free.
Old Jul 30, 2007 | 03:14 AM
wilboytsk's Avatar
at 50k you should be covered. Unless you got the extended warranty...60k is when the warranty ends...i've gotten that same error at 56k and dealer replaced it with no prob!
Old Jul 31, 2007 | 03:02 AM
Jason@Riverside's Avatar
Actually.. if you want to just replace with the same type of unit you have...
it can be done for not that much...
if local PM me about local info...
An exchange will be done, but I will have to get your factory unit before i can send out the new unit... PM for info on that with Zip...
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
ara777
Aug 15, 2018 04:11 AM
2_Liter_Turbo
Jan 19, 2018 01:48 AM
Frostbite91
Aug 2, 2015 04:59 PM
