ADDING SUBWOOFER PLEASE HELP!!!!!
Old Jan 26, 2004 | 09:07 PM
icontractor's Avatar
I was wondering, if i wanted to add a 10" or a 12" sub to the bose system would i have to add an amplifier or can i use the current bose amp thats already installed.
Also what if i wanted to replace the front door speakers with component speakers would i have to again install an amp or will the bose amp work??
Old Jan 27, 2004 | 11:31 AM
Micah's Avatar
Re: ADDING SUBWOOFER PLEASE HELP!!!!!
I highly recommend that you get aftermarket amps when you change speakers. You won't get good results from the Blows amps.
Old Jan 28, 2004 | 10:13 AM
Casino's Avatar
Yea Bose uses messed up ohm ratings for their speakers better off with an aftermarket setup
2003 Black , sunroof, leather,
splashguards, 8 wire Hypergrounding kit, 350Z intake duct, K&N filter.
Old Jan 28, 2004 | 02:38 PM
Morx's Avatar
Something that I've found out about the speakers in the G35 coupe is that it was 2 pair front/rear, and then it uses a pair of 6x9's for the low tones. Working in the business, a custom install we've done is replace both the front/rear speakers with components, and added a JL Audio 8w7 pro wedge box in the trunk. Fits perfect and then leave the 6x9's completely out and they act as a blow through for the woofer in the trunk.
Hopeful future owner of a G35 coupe ~
Picture Share
Feb 4, 2018 12:41 PM
mbe32
Nov 13, 2015 11:09 PM
JustinMKN1
Sep 18, 2015 03:40 PM
