Problem with power window
Old Aug 11, 2007 | 01:11 AM
amazing35's Avatar
Question Problem with power window
My passenger side window is going crazy. When I open the door it rolls down a 1/4" like always but when I shut it it wont roll up. Then when I try and roll it up I have to beat on the door panel, and when I do that the window rolls down even while im hitting the button to make it go up. Finally when it goes about half way down it will roll up all the way. Any ideas? Is it a bad switch for the window or is it the motor? I can hear the actuator making the noise like it is being pressed but it wont do anything.
Old Aug 11, 2007 | 01:19 AM
Deezflip's Avatar
do a search on the reset button of the window motor
Old Aug 11, 2007 | 01:44 AM
amazing35's Avatar
thanks for the advice
Old Aug 11, 2007 | 04:36 PM
OvaYahead's Avatar
motor might be going bad too. Mine gets stuck either all the way up or down. Now it wont even work when I hit the door.
Old Aug 13, 2007 | 11:33 PM
KPierson's Avatar
The G35 has had window motor/regulator issues since '03. This is nothing new. You didn't say what year yours is, but if it is an older one that is out of warranty you may be able to get this fixed under warranty since it is such a common problem.
Old Aug 14, 2007 | 01:04 AM
amazing35's Avatar
yeah its an '04. thanks for the info. i will pass by the infiniti dealership and ask them.
Old Aug 14, 2007 | 01:04 PM
lancer's Avatar
I took mine (04) to the dealership and they just replaced the motor. If it's under warranty then don't dick with it, just take it in and they'll fix it. Mine kept rolling down a few inches after doing the auto-up.
Old Aug 14, 2007 | 04:25 PM
BW350GTskyline's Avatar
i had that same problem only on the driver side i have an 04 coupe nd when i brought it in they said that my window tints are causin the motor to burn out luckly i have warrenty and they replaced it but the piece cost like 200 hundred something
Old Aug 14, 2007 | 05:06 PM
KPierson's Avatar
Ha, it's not the tint, it's a poor design.
Old Aug 14, 2007 | 10:10 PM
Meatshackle's Avatar
Deep Sea Moderator
That's just like the dealer to try and blame a few ounces of window film on a faulty design.
Next thing we'll hear is that tire protectant throws off the alignment.
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
