a/c wont turn off and radio not working.
#76
A/C Controls won't turn off and stereo issues
I had the same problem everyone else seems to be having. In Atlanta the guy to take it to is Nahed Abdulnabi @ Electronics Master Repairs on
Pleasant Hill Road in Gwinnett County (678) 957-0686.
He upgraded the power supply and had me rolling in a few hours for $300.00 with warranty.
GC
GC
#77
#78
AC Controls and/or stereo not working
This is a common problem, the dealership may say this is an Audio Finisher Problem. From my experience with repair of car stereo. This is a car stereo problem. I see this problem on a regular basis. I have also posted a video to help troubleshoot this system. See the website at www.carstereohelp.com/infiniti.htm
#79
If you're running an 03-04, you can pick up a $150 stereo from crutchfield.com they discount the Metra down to about $90 with the stereo purchase, and include the wiring harness and antenna adapter for free. Throw in a $42 dollar steering wheel adapter from amazon, and you have a brand new headunit for about $300 - which is almost guaranteed to have iPod support and an auxiliary input.
#82
#83
g35 fix
We can repair your radio problems please visit our web site www.carstereohelp.com or call 1-800-428-1919
thanks
thanks
#84
Just go to the DD shopping and resource list sticky, there's plenty of info to help you do it by yourself, otherwise, check the regional forums for somebody to give you a hand.
#85
i just got finished wiring up my metra kit along with a pioneer avh3200 dvd along with a steering wheel remote.i used the harness that has the rca plugs . everything works and sounds good but the rear deck speaker isnt working.what have i done wrong? Thanks in advance for any advice ,i appreciate it
#86
#87
#88
well as far as the parking break goes i got a neat looking toggle switch and hooked one side to ground and the other side to the head unit so when the radio says i can only veiw images while in park and the brake on all i do is toggle the switch one time and all is good. i have not got my deck speaker to work yet mainly because i havent climed in the trunk and removed the amp and speaker cover,when i do i think ican get an amp negative signal from one of the output and an amped positive signal from another output
#89
#90
Loose connection, probably, but the Metra a/c controls have failed before. Remove it enough to check the connection, and if it still fails, probably time to give Metra a call about a replacement.
