Bose Amp = 1ohm?
Old Aug 29, 2007 | 12:14 PM
Buggsy's Avatar
Bose Amp = 1ohm?
I just got off the phone with a reputable audio installer in the Tampa Bay area (Stereorama) that was suggested from people here. I've set an appointment to have some Infiniti 2ohm speakers installed but he told me that the stock Bose amp in the g35 only outputs 1ohm. Is this true? I tend not to believe him because everything I've read so far says that it outputs 2ohm.
Old Aug 29, 2007 | 01:34 PM
Gilley's Avatar
The Bose speakers have 2 ohm stamped on the back of them.
Old Aug 29, 2007 | 02:53 PM
Buggsy's Avatar
Thanks Gilley. I looked on the back of the front speakers and saw a "2" stamped on only one of them. The other has no stamp at all so I wasn't sure if that was the ohm rating or not.
The 6.5 infiniti fronts made a huge difference already. Hopefully the matching back 6x9s will also.
Old Aug 29, 2007 | 03:18 PM
Gilley's Avatar
My speakers may have different markings than yours. I think I even measured it with an ohmmeter at 2 ohms.
Old Aug 29, 2007 | 06:09 PM
lancer's Avatar
2 ohm speakers should actually measure out at like 1.8 or so, right... seems measured resistance is always lower than rated, since resistance increases when the speaker is loaded...
or am I just making it up...
Old Aug 29, 2007 | 06:55 PM
JTO's Avatar
JTO
As long as your above the ohm load rated on the amp it wont hurt. You may or may not get the most power out of the amp depending on how its designed but as long as its loud enough for you then i wouldn't worry about it.
The rated ohm load is a nominal load. The actual load will depend on freq and even the enclosure.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
