Can the factory keyfob be reprogrammed...
Old Sep 5, 2007 | 02:52 PM
MDFDG35's Avatar
I have a keyfob from my 2004 G35 sedan and was wondering if it can be reprogrammed to operate my sister's 2005 G35 sedan?
If so, how?
TIA!
Old Sep 5, 2007 | 10:33 PM
03Sg35's Avatar
search button is your answer
Old Sep 6, 2007 | 10:31 AM
WILLIE BEANS's Avatar
from what ive seen only the dealer and certain locksmiths have the capability to program a keyfob ..
Old Sep 6, 2007 | 08:43 PM
ttrank's Avatar
Grocery getter
Yes I would just take it to the dealer.
Old Sep 6, 2007 | 09:28 PM
GixxerSteve's Avatar
Not so. I bought a OEM keyfob from originalkeyless.com for about $50, it came with instructions to program the remote. Basically a series of turning the ignition key on and off several times and pressing the door lock button once or twice, then pressing the button on the remote.
I'll have to see if I have the directions when I get home, but again I have a 2003 and it might not work for other years. You can also purchase the programming directions from their website for $7.
Old Sep 7, 2007 | 02:30 AM
ashish's Avatar
just to clarify, does you sister have an I-Key? if so, you cant program a key fob from an 04 sedan to a sedan that uses the Ikey
Old Sep 11, 2007 | 04:57 PM
MDFDG35's Avatar
it is not an I-key. Just a plain old key with a standard Infiniti Key fob.
Gixxer - if you happen to have those instructions handy, I would greatly appreciate them!
Old Sep 11, 2007 | 06:30 PM
formulag35's Avatar
Here are the directions I used...
http://www.infinitihelp.com/Ownershi...am_key_fob.htm
Old Sep 11, 2007 | 06:43 PM
Jeff92se's Avatar
Red Card Crew
Yes IF both fobs are the same p/n
And try the DIY section before asking.
https://g35driver.com/forums/showthr...ramming+keyfob
Old Sep 12, 2007 | 12:43 AM
Looks like formula posted the correct instructions.
Old Jan 16, 2008 | 06:19 PM
Red_G35's Avatar
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.
(The hazard warning lamp will then flash.)
when you insert the key do you turn it at all?
Old Jan 16, 2008 | 07:42 PM
tennsc's Avatar
lol.. .yes it can.. I remember the dealer lost my keys and since I had my old Z keys he was able to reprogram my Z fob to my G.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
TurTLe*
Sep 29, 2015 01:43 PM
SuperSaiyan
Sep 23, 2015 06:13 PM
