Do I have Satellite Radio???
Old Sep 12, 2007 | 07:43 PM
sjryan1's Avatar
I have a new (to me) 2005 G35X. When I hit the radio button a couple times the satellite radio band comes up. Also, I have an antenna on the roof. So I was assuming that I had a satellite radio tuner installed. Although I can't seem to find where it would be installed in the trunk. When I tune the satellite radio to station 0, it gives me a "Radio ID", which I figured was further proof that I have a tuner. However, I can't tune to anything but station 0, and can't get the "preview" stations... Do I have a tuner???
Old Sep 12, 2007 | 07:49 PM
Mike_Deezy's Avatar
If you're getting a radio ID, then yes the SAT tuner is installed. You're not getting any stations because you have to activate your service. You'll have to call in to XM or Sirius, which ever tuner you have. You can check the top of your antenna to see which tuner you have, usually their logo is imprinted on the antenna.
Old Sep 12, 2007 | 07:52 PM
sjryan1's Avatar
More Info
Thanks for the prompt reply! That's what I figured... The antenna was factory installed and doesn't say anything, so no indication of XM or Sirius. And I guess one last bit of info I left out, is that if I try to tune to a station other than 0, it automatically puts me back to 0??? And if I try to use a preset to get a station other than 0, it says "No Signal" and then again, goes back to channel 0. On channel 0 it keeps displaying the Radio ID...
Old Sep 12, 2007 | 10:26 PM
Gilley's Avatar
Most sat tuner boxes in sedans are mounted to the back of the rear seat. Remove the cover and see what you have.
Thebaws11
Jul 2, 2021 11:36 AM
G35xdriver04
Nov 7, 2015 08:31 PM
Learned Hand
Oct 1, 2015 09:02 AM
Siciliang35
Sep 18, 2015 11:22 PM
mattdg35
Sep 14, 2015 11:28 AM
