drivers side front lower speaker turning on and off intermittently... help
Old Sep 19, 2007 | 02:04 PM
cloud's Avatar
Most people said its related to the BOSE HU but the problem is I have an avic-d3 in there and it's installed by a good installer (16psibrick). What's up with the speaker?
Old Sep 19, 2007 | 02:06 PM
Ca$hio's Avatar
Had the same issue with my 04 sedan. Turned out to be the HU, I had it replaced under warranty.
Old Sep 19, 2007 | 02:29 PM
cloud's Avatar
but like I said, I don't have the BOSE HU anymore but a pioneer avic-d3.
I hear something from the door though like a loose wire or something but it seems to be closer to the back.
i realize that at really low volumes the mentioned speaker would turn off but when i crank it up a little, it turns on.
Old Sep 19, 2007 | 11:40 PM
The Robert's Avatar
Hmmm...I had the same problem but that was when I had the stock HU, and when that would happen I would just give the HU a nice solid hit and it worked fine again. Perhaps it is a problem with your aftermarket HU. I havent had any problems with mine though (kenwood dnx7100) but I also dont have the stock speakers anymore. Try taking it back to the installer and see what they say.
Old Sep 20, 2007 | 08:55 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Do you just have the D3 HU and stock amp/speakers? If so, there have been problems reported with the clipping of the front speakers due to the something wrong with the Bose amp. Could there be a faulty wire connection with the speaker wire harness between your D3 and stock wire harness.
But, if you also swapped out your stock amp/speakers with aftermarkets, it could be a loose speaker wire at the amp or a loose wire at the speakers or something going on behind the HU with the RCA interconnect.
Hope this helps.....
doc
Old Sep 21, 2007 | 07:27 PM
broke_as_ajoke's Avatar
i have a 07 coup. i got the same problem it just started last night... i just have the plan HU.. so i turned it up as loud as it could go and it worked again... but i got a feeling its gonna act up again
Old Sep 21, 2007 | 07:29 PM
GR6RR's Avatar
wut?
me too...
only when I drive though.. like when I roll on to uneven pavements or little bumps it'll turn on and off.. i took the door panel off but.. didnt see anything wrong..
still have the problem.. maybe we can all help each other on this one..
Old Oct 31, 2007 | 06:57 PM
cloud's Avatar
anyone figured out the problem yet?
i have the D3 with stock bose speakers/amp
Old Oct 31, 2007 | 10:45 PM
Gilley's Avatar
You must have a loose connection somewhere.
Old Dec 19, 2007 | 06:07 PM
blownvert's Avatar
i also have this problem it just started. i have the pioneer avic z1. I dont know what i should do? I was going to take off the passenger front door panel and see if its a loose wire. It goes on and off passenger front right side. help
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
attarday
Jul 15, 2015 04:03 PM
