Is there a way to add a third Cigarette Lighter??
Old Sep 26, 2007 | 07:38 AM
Manny2ksi's Avatar
Talking Is there a way to add a third Cigarette Lighter??
Or another 12v power supply. i wanna hook up my PS2 to a new 12v and i dont want to use the front one (radar detecor) or the arm rest one... (cell phone charger.
i pefer to make a new one to put behind the glove and just wire a switch to it to turn it on or off??
anyone???
Old Sep 26, 2007 | 08:20 AM
pjames's Avatar
i guess there's only two in the coupes? or newer ones at least, in the sedan (late 2003 at least) there are three, one either side of the console and one in the armrest.
you can buy the sockets, i would run it off a relay from battery, switch by the accessory power (on with the car in acc or on), you can put a separate switch inline with the lead from the relay to the socket, if you desire, but wouldn't be nesc.
Old Sep 26, 2007 | 09:56 AM
Gilley's Avatar
My 04 coupe has 3 power outlets which dropped to 2 for 05.
Look at this thread for the best way to power you PS2 via a direct power wire to the battery.
https://g35driver.com/forums/showthr...ighlight=relay
Old Sep 26, 2007 | 12:48 PM
g35rcr's Avatar
where is your 3rd? i know there are 2 on each side of the stereo...btw they make a 2 way splitter for the cig lighter
Old Sep 26, 2007 | 12:57 PM
Mitsuko's Avatar
you can wire a couple more simply by tapping into the back of the original lighters. me personally i don't like clutter and wires hanging out, so stuff that will always stay plugged in (cell charger, radar detector, ipod charger, ac/dc inverter) i wired more outlets and hit them inside the dash, and have the connectors sticking out where i would need em (center console, dash window).
fairly easy to do, lemme kno if you want help on it, i just simply tapped into the harness to avoid wire splicing. just don't overload it, each cigarette lighter is rated at 15A, so on the safe side if you load as much as i do split it between both lighters (different wiring and fusing for each)... and cell chargers/ipod/radar are relatively low power so all those can go into one side
for your case, ps2 and radar detector will handle on one. you can wire directly to the battery, but that just overcomplicates the whole concept... i only say do that if you're doing a high power ac/dc inverter or something over 200w
Gilley's Avatar
I meant that my sedan has 3. My coupe has 2.
Old Sep 26, 2007 | 01:42 PM
g35rcr's Avatar
i thought about adapting the sedan cig lighter to my coupe, but i lost interest in the project
Old Sep 27, 2007 | 02:03 AM
Meatshackle's Avatar
Deep Sea Moderator
If it's for a PS2, hardwire an invertor to the battery with a switch. Now you have concealed power to your PS2 and you have 110 in your car for anything else as well.
Old Sep 27, 2007 | 05:26 AM
g35dguy's Avatar
woot! -.- crazy.
KruZZe
Feb 27, 2023 05:04 PM
JKL1031
Brakes
19
Aug 30, 2016 08:48 PM
Tmatheso
Dec 13, 2015 03:24 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
